Anyone do this? I just bought a set of ccw's (17x12) to run all the way around, and was curious what the consensus was for running the 315/35/17's on the street.
#2 | |
![]() Join Date: Aug 2006
Also, due to extra width/grip in the front relative to factory intent, you could introduce oversteer. Please understand that I am no suspension engineer - just my thoughts. |
#3 | |
![]() Join Date: Nov 2006
I've seen several c4's run that combo on the road track with good handling results'. I was going to buy a set a while back and tried mine on the front just to see how it looked, but didn't like the way they stuck out with the 36mm offset. Not sure, but I think the ones at the track were not the 36mm on the front.
#6 | |
These might stick out some (maybe an inch on the sides up front). Go with 10's on the front 285 / 40 / 17 and 12's in the rear 335 / 35 / 17. ![]() ![]() David |
![]() Join Date: Jan 2009
They will rub when you try to turn.
![]() Join Date: Nov 2008
Won't stick out, won't rub. CCW knows their stuff!
These are 17x11 fronts, 17x12 rears. ![]() ![]() |
#9 |
![]() Join Date: Dec 2004
I have run 315's on all 4 corners on the track with correct offset wheels. Worked fine except tough on power steering at very low speed.
Curtis |
#10 |
Yup, It can be done.
Here is Ed (FastZR1) with 315s all the way around. ![]() |
