Old 12-21-2003   #1
shor
Default optima battery in zr1
can it fit?
it is about 1 inch longer.
has anyone installed one?
shor is offline   Reply With Quote
Old 12-21-2003   #2
zr1mom
zr1mom's Avatar
Default
From one of my members:
After very minor modifications to the tray (trimming the centering tabs
so the tray was wide enough), the battery "fit," but the clearance between the positive top post and the cruise control servo bracket was too close for comfort for me.
I removed the cruise control servo and bracket. Although, modifying the
bracket by notching it out would not be that big of a deal if you like cruise
control.
Some people say the battery fits their car. I presume they are counting
on the thin plastic terminal insulator to prevent grounding. I would not do
that with the clearance that was available in my (stock) car.
Other members of the net cut the positive top post off. However, two of
them report battery failure shortly after cutting the post.
ZR-1 Mom
Founder ZR-1 Net Registry
Founder ZR-1 Net
zr1mom is offline   Reply With Quote
Old 12-21-2003   #3
shor
Default
Thanks
I usually put Optimas in all of my vehicles, but I guess I'll just get a replacement GM one, the correct size for the ZR1.
