Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 NCRS for ZR-1s
Old 02-24-2010   #1
phrogs
phrogs's Avatar
Default NCRS first things to do
If you all want to have your car judged do yourself a favor and order the judging manuals for your year and go over them and judge your car yourself! you'll learn alot and be ready to be judged.
join the NCRS and your local chapeter you don't need to but at least educate yourself on the rules and regs.
JOHNNY P
Currently own
phrogs is online now   Reply With Quote
Old 02-25-2010   #2
95 LT5
95 LT5's Avatar
Default Re: NCRS first things to do
X2
'95 ZR-1
RED/GRAY
#261
'95 ZR-1
BLK/BLK
#268
'89 6-Spd
FX-3,Z51
BLK/BLK
95 LT5 is offline   Reply With Quote
Old 02-25-2010   #3
Cdn ZR1 95
Is a '95 eligible now and is there a manual for it?
Cdn ZR1 95 is offline   Reply With Quote
Old 02-26-2010   #4
jrd1990zr1
jrd1990zr1's Avatar
Looks like the 94 &95's are being judged at the Gettysburg regional.
Check the NCRS store for manual availability. NCRS.org
Old 02-27-2010   #5
1989ZR1#74
1. Battery cut off switch
2. NCRS window decal
3. Fire Extinguisher.
Bonus raw points. Make sure you have all three.
Find a Chapter meet in your area. Sign up to be an observer judge first. You will know what matters and what doesnt before you put your baby on the field.
1989 ZR-1 #04 Pilot, Advertising/PR Campbell-Ewald S9YKH1
1989 ZR-1 #58 LT5 only
1989 ZR-1 #74 Unreleased Production / PR Dept 9PR110
NCRS #3,182 SACC #2,420
Member Corvette Museum
Corvette Forum: "ewjxn"
2009, 2010 Gathering Attendee
1989ZR1#74 is offline   Reply With Quote
Old 12-06-2010   #6
40zr1
Re: Battery cut off switch. What type and where would be a good location?
I'm thinking of going to the Florida winter meet, any additional points would be nice. The only thing that I know is wrong on my car, I have SS brake lines instead of rubber hoses from frame to wheel. But I'm not going to change them just for judging.
Thanks
40zr1 is offline   Reply With Quote
Old 12-07-2010   #7
jrd1990zr1
jrd1990zr1's Avatar
The type of cut off does not matter in order to get the bonus points. They connect directly to the battery. BTW, having a non-AC Delco battery will cause a point deduction.
SS lines by themselves should not prevent you from getting a top flight. The point total for the car is about 4500 points. You will lose points for the lines but I wouldn't change them for judging. I just had my 1990 Z judged with braided oil cooler lines, result was not that bad.
The place where you can get the biggest deduction is in the operations of the car. If you are going to attend the Florida regional you should download the judging sheets from the NCRS website and with the judging guide do a trial judging of your car yourself. I would concentrate on operations first, then mechanical and chassis. Like I said above make sure all of the car operations work.
Good luck in your quest for top flight!
Old 12-08-2010   #8
BLACK90ZR1
BLACK90ZR1's Avatar
Make sure that you have a good battery, and that is fully charged, Leave you under hood lights disconnected until time for judging them. The CD player may not operate unless the battery is fully charged. I lost points for that one time. I had it fixed and I. I was getting ready for another judging and it wouldn't operate agin. I charged the battery and it operated fine. I bought another battery for my Crossed Flags judging.
BLACK90ZR1 is offline   Reply With Quote
Old 12-08-2010   #9
1989ZR1#74
Thanks
Harbor Freight sells them be careful hard to leave that store without buying more stuff!
I echo the ops check and also:
1. check your glove box for the appropriate manuals and cards.
2. Take both sets of keys and the knock outs if you have them. If not get a second set of keys made with the correct letter keys.
3. Bring a couple clean beach towels and flashlights. (towels are universal covers, kneel pads, fender covers, can be used to block sunlight so they dash lights can be checked etc...)
4. Car needs to stay on the judging field until meet is over.
5. It needs to be uncovered from the morning until the field closes at night.
Have fun..
Eric
Old 12-08-2010   #10
Are u saying Pete's car wouldn't make it?
