Old 02-16-2010   #1
secondchance
Default "C" beam plates
A couple of questions regarding beam plates:
1. Where can I get them?
2. Is it necessary to remove exhasust to install? Is it relatively simple procedure?
Old 02-16-2010   #2
tccrab
tccrab's Avatar
Default Re: "C" beam plates
They're made by Bill Boudreau, the "ZF Doc":
http://www.zfdoc.com/c4beamplate.htm
They're not that hard to put on, figure on spending a Sunday afternoon, 2 or 3 hours at most. It might be possible to put them on with the exhaust in place, but there's not a lot of room under there. It's not that difficult to remove the exhaust.
TomC
'Crabs
Old 02-16-2010   #3
Scrrem
Scrrem's Avatar
Yun,
I put mine on when I installed my 4.10's and had the exhaust off anyway. I don't think you would have enough room to get the bolts out with the exhaust in the way. It's a piece of cake once you have the exhaust off Sounds like a job for WAZOO!!!
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 02-16-2010   #4
secondchance
Thanks guys.
Yes, Rich. Sounds like one of my "to do" list item.
Rich,
Did you notice any difference after the install?
Old 02-16-2010   #5
Scrrem
Scrrem's Avatar
Thanks guys.
Rich,
No, but I have been baby'ing the Z with the new gears for the first few hundred miles or so. I'll let you know at BG once I get my first run down the drag strip
Rich
Ron Davis Radiator
Old 02-16-2010   #6
tccrab
tccrab's Avatar
Thanks guys.
It is VERY noticeable the first time you hammer the throttle after installing them.
Worth every penny.
TomC
'Crabs
Old 02-16-2010   #7
QB93Z
QB93Z's Avatar
Once some of this snow melts, we will schedule a WMD and we can put the C-Beam Plates on your car. I have a set here that you are welcome to use and replace if it turns into a long-lead time item.
Old 02-16-2010   #8
tccrab
tccrab's Avatar
You might want to check with ZFACTOR, we may have some available at the Registry store.
JeffVette may have a set or two also.
TomC
'Crabs
Old 02-16-2010   #9
jonszr1
jonszr1's Avatar
i have them on both my cars ,and love them . especially when you get on her in first gear and hit second the car goes dead straight .before them she really kicked out the rear end . and the other plus is ,if and when, you have to remove the rear end and tranny it makes short work of putting the bolts back on. to me its a must do
Old 02-16-2010   #10
secondchance
Thanks guys.
I will order from ZF doc and see.
Thanks for the offer Jim. Hopefully it's not a long lead item.
