Old 05-18-2017   #1
TealZR1
Default Idle Issue - Yes Another
After opening her up a bit and as I come to a stop, idle wants to stay at 2000rpm or so. I tap on the gas pedal, she comes down to 750 rpm. Anything in particular I should look for? Thanks in advance...
TealZR1 is offline   Reply With Quote
Old 05-18-2017   #2
Roadster
Roadster's Avatar
Default Re: Idle Issue - Yes Another
This is directly from Marc Haibeck's website.... zr1specialist.com
"High idle speed is most commonly caused by a vacuum leak. The throttle body can cause a high idle if a throttle plate binds with a bore.*If the high idle is intermittent or goes away when the accelerator pedal is kicked, the high idle is caused by the throttle body. If a light tap fixes the idle, the problem is with the primary throttle. If a hard kick to 25% throttle or more helps, the problem is with the secondary throttles."
Hope this helps....
1974 LS4 454 Vert
Old 05-19-2017   #3
ssrszz4
So a vacuum leak would cause a constant high idle?
Sent from my XT1585 using ZR-1 Net Registry mobile app
ssrszz4 is offline   Reply With Quote
Old 05-19-2017   #4
G8nightman
G8nightman's Avatar
Yes
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
Old 05-19-2017   #5
TealZR1
I am the original poster about the idol issue. The fact that as I coast down to a stoplight it sticks out about 1600 RPM, I tap on the pedal and it goes back down to 650 RPM, I may have a problem with the primary secondary cable?
Old 05-19-2017   #6
Billy Mild
How many miles? I bet your throttle body needs a service.
Looking for a ZR-1
1985 Yamaha RZ350-NOT STOCK
1971 Yamaha AT1-Middle of a restoration
Old 05-23-2017   #7
RICHARD TILL
You may be experiencing a normal situation. My car doesn`t return to normal idle speed until its fully stopped.
Old 05-24-2017   #8
TealZR1
Thanks to all who have responded. By the way, what things need to be done to service the throttle-body
Old 05-24-2017   #9
ssrszz4
My '90 does the same thing sometimes, after about 10 miles or so when it's heated up it comes back to normal idle.
