05-18-2008 | #11 |
Re: Finally drove the Z.. But have issues>>
Yea on the Q-driver....pulled that one from you know where.
If you think it's the O2, switch'em & see if it follows...if not then I gotta suspect an injector(s) maybe. My thinking is that ya have to mechanically verify what each O2 is telling you about the results of combustion in that bank, pull the plugs & or stand behing the car & sniff the exhaust when it acts out....gotta pass the smell test. JMHO.
05-18-2008 | #12 | |
So, it can happen that way. However, a loose or intermittent O2 connection might give you the same test results. Swapping the sensors** to see if the problem tracks seems like a good approach. **Would it make sense to build a wire harness that would allow you to simply cross-connect the O2 (connect the left O2 to the right ECM harness, etc) and avoid having to acutally swap them?? P. |
05-18-2008 | #13 | |
I'd be more concerned over the issues that could cause more than the inconvenience of swapping them. |
05-18-2008 | #14 |
Installed new O2, apparently the old one was not plugged in all the way.. I changed it anyway.. Went drive it and I had no clutch pedal, the master I installed was sticking.. swapped that and just drove it again.
I am stumped/annoyed. the O2 problem I saw is fixed but the loading up stumble and die is still there.. I don't see anything in the scan that could cause it.. It seems to be there slightly in Open loop, worse in closed loop ( to the point of the car dying.. not sure where to go next.. Strangest thing.. car is running like crap.. pull it on my lift shut it off. wait 10sec, start it.. runs/idles fine.. Now here is what I changed over the winter: Plugs Wires Injectors BIN in PROM used a different plenum and IH but I don't think there is an issue there.. Things I am guessing it could be: Ignition module? Coil Packs? BIN IN PROM
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - 3" Magnaflow Bullet cats - LT4 Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 Last edited by -=Jeff=-; 05-19-2008 at 03:22 PM. |
05-18-2008 | #15 |
Jeff,
Give me a call. |
05-19-2008 | #16 | |
Re: More Foreign Leaders Express Their Condolence to China on the Earthquake Disaster in Sichuan (XVI)
[I][FONT=Comic Sans MS]John Boyd[/FONT][/I] [I][FONT=Comic Sans MS][SIZE=1]Ideho[/SIZE][/FONT][/I] [FONT=Comic Sans MS][SIZE=1][I]2015 ZL1 [/I][I]Camaro #1121 BLACK/BLACK 6 SPD (540 RWHP)[/I][/SIZE][/FONT] [I][FONT=Comic Sans MS][SIZE=1]1991 ZR-1 #458 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK 72[/COLOR]k miles ([B][COLOR=red]SOLD[/COLOR][/B]) 1991 ZR-1 #473 [COLOR=red]RED/[/COLOR][COLOR=black]BLACK [/COLOR]37k miles ([B][COLOR=red]SOLD[/COLOR][/B])[/SIZE][/FONT][/I] |
05-19-2008 | #17 |
WTF.
We need to register with a real working phone # with matching address before we allow anyone to post,this way we know where he lives and can pay him a visit. Jeff, i would try the prom first,then move to coils. If it's ignition $$$$$$ module i would figure out a way to use LS1 coils. Pete
'91 #1635 PoloGreen 350 LT5 11.09 @ 129.27 11.04 @ 128.86 474RWHP 400RWTQ http://www.youtube.com/watch?v=SFNFOhGGlR4 http://www.youtube.com/watch?v=ZlRIOMwaDYY https://sites.google.com/site/peteszr1garage Last edited by Pete; 05-19-2008 at 02:17 PM. |
05-19-2008 | #18 | |
I swapped the PROM last night, I goign to use the OEM AYBK that I have. I ordered coil pack too, I figure I will pull the plenum tonight or tomorrow to swap them (should have them this week) and see what that does. after reading RogerZr1's post, mine issue sounds the same, bbut my car dies, makes me think it might be coils
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - 3" Magnaflow Bullet cats - LT4 Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
05-19-2008 | #19 |
jeff does it die after the car get up to operating temp? if so it could be coils .heat over time kills them .good luck
05-19-2008 | #20 |
Fixed.. bad PROM
put in a Stock AYBK works fine.. Now to disable cars..
