Old 09-21-2020   #1
Erik
Default Anything unique about a LT-5 Alternator?
The bearing in my alternator is a bit noisy, so I?m thinking about changing it while everything is apart. Is there anything different about them, or just standard GM?
1990 ZR-1 # 996
Old 09-21-2020   #2
viper107
viper107's Avatar
Default Re: Anything unique about a LT-5 Alternator?
I think they are readily available
Old 09-21-2020   #3
Andy
Mind you get the same size pulley or r&r the one you have.
1990 black on black #1042 - sadly - sold
1993 Ruby #140 - stock
1991 QB #1608 - heads and top end ported, Watson headers, B&B 3"exhaust, Haibeck chip, 4.10 gears
Andy is offline   Reply With Quote
Old 09-22-2020   #4
CamP
Have it rebuilt. It's a simple job.
CamP is offline   Reply With Quote
Old 09-22-2020   #5
ZWILD1
ZWILD1's Avatar
Try and really isolate the noise and make sure it's the alternator . I made that mistake with my 96 LT1 coupe. I have that alternator sitting in my parts collection. I was sure it was the alternator and swapped it out. Upon starting the car the noise was still there. It could have been the power steering pump or possibly the ac compressor. I even tried the screw driver trick and it sounded like I could hear it coming from the alternator. I would try a stethoscope or maybe removing the belt all together and turning each accessory pulley including the water pump.
91 Turquoise Metallic Haibeck 525 #0134
ZWILD1 is offline   Reply With Quote
Old 09-22-2020   #6
Erik
Thanks.
It is the alternator. The bearing feels rough. But we are checking the other stuff too. Good reminder to get.
1990 ZR-1 # 996
Old 09-22-2020   #7
Erik
Is there a great guru of alternators, who could rebuild it with quality parts, and perhaps up the output some?
1990 ZR-1 # 996
Old 09-22-2020   #8
CamP
Im sure you can find a local auto electric shop to do it. It's an easy job. I've done them myself in the past.
Old 09-22-2020   #9
CamP
Link to youtube tutorial.
https://youtu.be/1Y1j6sNS9nA
Old 09-22-2020   #10
Only thing to be aware of is our Alternators are the early CS-144 housing.. there are 2.. Early and late, the Late housing will not fit in the 'pocket' where ours are installed.
I rebuilt mine with better parts to output a bit more power, along with an additional 8 gauge wire back the the distribution terminal and adding all the LEDs.. it all helps
Watson Headers (2" Primary) - 3" Magnaflow Bullet cats - LT4 Catback
