Old 03-15-2024   #1
phrogs
phrogs's Avatar
Default Any Idea what that noise is?
Looking for opinions what do you hear?
It is a DRM 500 package top end ported It has aftermarket connecting rods, after market pistons marked PMI388/I not sure about the cylinder liners, and I am pretty sure it had Nitrous run on it from the holes drilled in my storage compartment.
I have no idea the abuse this engine had prior to me getting it but it has been fine for 19 years with a couple of misfire issues here and there.
I have been driving it as a daily for years and it has always puffed a little oil smoke.
I know I have something going on so im not to worried about it just want to figure it out before I yank it out.
Video
https://www.youtube.com/watch?v=5V4tnQdGc6Q
I had Amsoil 10w40 high zinc in it put in last spring.
I checked all over the place with my mechanic stethoscope couldn't really isolate it.
Oil pressure was still good
Last compression test was good but I have not checked it yet.
I am pulling the oil pan to check for anything obvious I'm guessing a rod bearing.
lifter? piston ring? piston slap or a rod knock.
I cut open the oil filter and I have small ferrous metal in the filter not a lot but some.
Anyway why do you all think it is?
JOHNNY P
Currently own
90 #226 Might be a parts car not sure yet
Old 03-16-2024   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Any Idea what that noise is?
Sounds like you have some piston slap.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 03-16-2024   #3
tiegsd
tiegsd's Avatar
Seems to be one "tick" per engine revolution (i counted 15 ticks in about 2 sec at idle).
1990 Black/Black ZR-1 #1155
Old 4 Weeks Ago   #4
Tim555
The ticking noise sounds sort of like an exhaust leak. Does it go away when it warms up?
Tim555 is offline   Reply With Quote
Old 4 Weeks Ago   #5
when my 90 was stock it made that noise 90-966, and when I put a different engine in it made the same noise.... 90-702 motor. There were some cam noise issues on 90s, I never figured it out on my car.... and it never showed knock.
Old 4 Weeks Ago   #6
Noise also came and went w/weather...
Old 4 Weeks Ago   #7
phrogs
phrogs's Avatar
well I found my knock sensor plug melted still have to check if that may be part of it.
JOHNNY P
Currently own
Old 4 Weeks Ago   #8
Johnny, maybe it just as simple as this... --Bob
Old 3 Weeks Ago   #9
phrogs
phrogs's Avatar
**** I wish.
Lee mentioned a little thicker oil so I'm going to try that and see if it changes.
I needed to fix a rear main seal leak and that pan gasket as well so almost ready to fire it up. So we'll see.
JOHNNY P
Currently own
Old 3 Weeks Ago   #10
scorp508
Totally different engine, but my L98 had a loose valve guide sound very similar to that clicking. I kept adjusting my rockers thinking one was loose.
1987: Z51 Coupe, Z51, 4+3, Yellow / Graphite
1994: ZR-1 #150, Admiral Blue / Black
2015: Z06 Coupe, Z07, M7, Arctic White / Red
scorp508 is offline   Reply With Quote
