07-24-2014 | #1 |
A question about rear brake calipers.
I want to have an extra set of calipers,brackets powder coated.What year rear calipers are used on the base car as well as a ZR-1?Ive got the fronts,just need the rear setup.Thanks,Jeff.
07-25-2014 | #2 |
Re: A question about rear brake calipers.
88-96
87 was the last year for the drum e-brake on a C4
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - 3" Magnaflow Bullet cats - LT4 Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
07-25-2014 | #3 |
07-25-2014 | #4 |
I am staying out of this one!!!
07-25-2014 | #5 |
07-25-2014 | #6 |
This is a typical image for '88 -'96 rear calipers and items #6 (pivot) and #4 (lever) are a one year only for '88, sure the caliper would fit BUT there would be no servicing those two components if you had problems without again acquiring an '88 caliper. The lever and pivot are the apply mechanism for the parking brake. It's not unusual to need to service those on cars where the parking brake sees little or no use.
I mentioned the newest MY and the least number of miles if you were shopping. Can you tell the difference visually? I really don't know. I can tell you the repair solution was to buy the later caliper if you had problems with an '88. rear caliper.jpg |
07-25-2014 | #7 |
So what is the difference on the 88? Do you have a comparison picture?
07-25-2014 | #8 | |
Does this work for you? '88 rear: '88 only rear.jpg '89+ rear brakes '89 - '96 rear.jpg I did have these on an electronic image for you Last edited by WVZR-1; 07-25-2014 at 07:09 PM. |
07-25-2014 | #9 |
Not really related but I did discover that the 88 KOH Prototype rear brakes have a one-off rear rubber brake line style. The steel brake line that the rubber hose is crimped onto is bent differently than an 89-95 flex line.
07-25-2014 | #10 | |
Thanks for the info but it does not help.. Reason I ask if you had a picture of the E-brake mechanism, is my e-brake does not work on my 90.. so if there was a distinct difference int he arm I could check it and that could be why the brake does not work. in the pictures they look the same, which is why I was asking if you had a comparison picture of the actual pieces.. I knew the 88 was one off on a lot of things, I did not realize the Ebrake arm was one of those things. Now I have to wonder if the rear calipers I have are 88 or if they are correct ( They have been replaced due to the set on the car not working either) Now that the post is way off track of the OPs question.. I apologize
