Old 06-02-2017   #1
aafc
aafc's Avatar
Default modified forced air systen
Here are photos of my modified forced air lid. Still working on painting new air lid.
The opening is larger then the org. forced air system, this should give me
a little more top end while racing. Now this new system will not be used
on the street because of (rain/ standing water) . It will be used for drag
racing only. Testing will start when the rain stops here in sunny FL.
Org forced air lid
Opening for Org forced air intake
New filter lid mounted to K&N filter
K&N filter with new filter lid
Old 06-04-2017   #2
billschroeder5842
billschroeder5842's Avatar
Default Re: modified forced air systen
Great work. Where did you come up with the design?
Bill Schroeder
Texas Proud!
1991 Corvette ZR1 #1388
Old 06-05-2017   #3
aafc
aafc's Avatar
Early on they made open element lids for the filters (stock/K&N), but there was no way to route air through the front bumper.Then A/O Engineering made
the Forced Air System by drilling a 5 in hole thru the front bumper. Now fresh
air it routed thru the front bumper to the Forced Air lid. That worked good,but
the 5 in hole was limited to move air to the filter because the opening on the
lid is reduced by 25-30% opening. So by using the 5 in hole i made a ramp
to the open filter lid. So now the ramp directs all the air into the open filter lid.
Which could mean more power at top end. More air in more power out (this
might require a little tuning to take advantage of more air).
When the hood is closed it rests on the lip of the new filter lid so more incoming air goes into the filter.
The photo below shoes the org Forced Air System with my modified filter
lid next to it.
