Old 10-27-2014   #1
Mr Blue
Default SYS MESSAGE
My 1991 # 1408 started flashing SYS in the mileage display as I was driving to work today. I had to put a battery booster on it, as it had been sitting long enough to have low battery. Other that that it started and ran fine, just that annoying message intermittently. I have not seen any threads on this message, and would welcome help on what to look for.
Mr Blue is offline   Reply With Quote
Old 10-27-2014   #2
Default Re: SYS MESSAGE
You can find out what it is with a scanner, or Gordon Kellebrew sells a set of grounding plugs that allow you to read them using the dash. I'm sure someone else may have a link to what ALDL points to jump to do this and use the dash to diagnose. It may even be in the FSM never looked for it as I have the plugs and a scanner..
http://www.gordonkillebrew.net/Products
Steve
1990 Steel Blue/Black #2355
1990 Red/Red #1473
1991 Quasar /Black #118 Sold
1993 Yellow/White #179 Sold
Old 10-27-2014   #3
batchman
I often get the SYS message when my lightweight battery is in a marginal state of charge. Let your battery come back to life and it should go away - only real impact is it won't allow secondaries.
My answer was to keep it on a tender.
Cheers,
- Jeff
[I]91 ZR-1 #1840, autocrossing in SCCA BSP. FIC S/S's
DRM chip/Watson/Borla/lid/LW batt&headlights,
springs, shocks, pads & lines, quick rack & Turn One,
camber brace, 32/22mm sways, A/C halfway deleted
17x11 & 12 CCW's, 315 & 335 Hoosier A6s
[/I]
Old 10-27-2014   #4
ghlkal
ghlkal's Avatar
Here's how to check what the SYS code is ...
http://www.zr1.net/forum/showthread.php?t=17846
I've also experienced a SYS if the battery is low ...
1990 ZR-1 #2180 Red/Black
Many of the usual mods for 460HP, tuned by Marc Haibeck
ZR-1 Net Registry Member #1548
Old 10-30-2014   #5
Mr Blue
Thanks everyone
It appears that this was a battery charge issue. After I drove the car and the battery charge was up, no more message. I learned a few useful things anyways. I'll keep the car on a float charger from now on.
