Old 11-25-2012   #1
Scrrem
Scrrem's Avatar
Default No Lumbar...
Well, I decided the interior has been neglected long enough and decided to tackle my non-functional lumbar. Once I determined my pump was good, I dove into the seat bladder. What I found was three rotted out connectors at the bladder, new bladders in route.
Rich
1990 Bright Red Coupe #608
Coated SW Headers / Corsa
Ron Davis Radiator
Pioneer AVIC-Z140BH NAV
Old 11-25-2012   #2
vettn71
Default Re: No Lumbar...
They only see to last 10 to 15 years. I'm on my third set, since new. The nipples just seem to rot off, while the rest of the inflator seems okay. Makes me wonder what will happen when GM no longer offers these
vettn71 is offline   Reply With Quote
Old 03-20-2013   #3
msmoore
Hey guys! Where's the best place to get these lumbar replacements? I fixed my pump and it's blowing air but still nothing happens in the seat. Any trick to getting to to the bladders?
I also found that the white connectors under the seat were all cracked so I just joined the hoses on each site of one of the black nipple connectors
msmoore is offline   Reply With Quote
Old 03-20-2013   #4
Blue Flame Restorations
Sounds like a good part for one of you guys to reproduce.
1990 ZR-1 #444 Convertible
1990 ZR-1 Black #966
1991 ZR-1 Quazar Blue #296
1957 Duntov SS Project
Old 03-20-2013   #5
scottfab
scottfab's Avatar
I guess I'd like to see an aftermarket one that's bigger than stock.
It's good to see no one ripping these things out. They fail from time to time but hey..... for back problems on long trips they're worth fixing.
Scott
Old 03-20-2013   #6
Why would they rip them out just because they are bad? Too much work for no gain. Needs a more robust design for sure.
Old 03-21-2013   #7
Because Scott says so.....he likes the word rip or ripping lately
See Lumbar pump repair
Old 03-21-2013   #8
Scrrem
Scrrem's Avatar
The bladders are a VERY difficult part to find, not many people carry them. I had standing orders with both Corvette Central and Eklers for over 4 months and neither could get them in stock. I was finially able to find one at this place:
http://www.corvettepacifica.com/ , Not sure if they are getting any more.
You will need a good set of cutters to cut about 10-15 hog rings to get the bladder out. You will need to buy a set of hog ring pliers and a couple bags of hog rings to re-secure the seat cover to the foam. Take some pictures as you go to help you remember where the hog rings go. Yeah, it's a lot of work for little gain, but my I can't seem to shake this anal-retentive nature I have for everything to be working.
Rich
Ron Davis Radiator
Old 03-21-2013   #9
I have also seen them on eBay too.
the 94-96 bladders seem to be of a better design but are shorter in width, although they might work in the earlier seats
Watson Headers (2" Primary) - 3" Magnaflow Bullet cats - LT4 Catback
Old 03-21-2013   #10
LancePearson
LancePearson's Avatar
I've had a number of gm and ford vehicles over the years with inflatable lumbar supports and they all, every single one, fail or start to not hold air in a very few years. When and if I take my seats out I am going to custom replace them with closed cell reasonably stiff foam in those spots and disable the function completely. Pretty much useless from my point of view over time as is.
Lance
Lance Pearson
Chester, Virginia
[COLOR=red][I]'76 L48 four speed[/I][/COLOR]
[COLOR=red][I]'91 ZR-1 #00682[/I][/COLOR]
Net Registry #1461
LancePearson is offline   Reply With Quote
