Old 01-15-2024   #1
zr1vetteguy
zr1vetteguy's Avatar
Cool SYS Light on Dash
Hello,
Have a 90 (#2833) that I have owned for about 7 months. Haven't driven the car in about two weeks but try to run it about 50-100 miles every week or so.
This morning a SYS light came on in the area that displays fuel info. Comes on periodically every 20-30 seconds or so and then reverts back to fuel info.
What system is having trouble?
Thanks in advance!
zr1vetteguy is offline   Reply With Quote
Old 01-16-2024   #2
tccrab
tccrab's Avatar
Default Re: SYS Light on Dash
Usually means it's time to replace your battery.
It's a CCM code, means the battery is less than 12v.
Crabs
TomC
'90ZR1 #792
Honorary Pirate
[/B]
Old 01-16-2024   #3
Matt B
Matt B's Avatar
As Crabs says: battery. You may also want to check the battery pole bolts for loose connection. I had a cross treated battery terminal causing power fluctuations.
ZR-1 #638/1991
Matt B is online now   Reply With Quote
Old 01-16-2024   #4
zr1vetteguy
Thank you both for the feedback! Will check the connection and likely replace the battery for good measure. Thanks again!
