11-06-2022 | #1 |
Re: Dreaded no start
Had the exact same issue, put in a new battery and problem solved but to be sure will rebuild the starter as well during our next Wazoo maintenance day.
11-06-2022 | #2 | |
Hope it is just the battery. I know the previous owner had had the plenum off, so l will check with him if he did the starter. |
11-19-2022 | #3 | |
BINGO. At this point I haven?t been able to get a no start on a warmed up / hot engine. Thanks ?dredgeguy? for the recommendation. I will purchase a starter solenoid plunger and contacts kit anyway for when and if l do pull the plenum at some point🫰 Cheers from down under 🇦🇺 Russell |
