Old 07-29-2016   #1
Default Bleeding brakes - easy way!
With the right equipment, bleeding the brakes takes less time to do than it does to remove and reinstall the wheels to access the calipers - more or less.
If you're like me, and always dreaded bleeding the brakes (or the clutch too, for that matter), this stuff/method might make it a lot easier for a DIY'er.
Tools:
  1. Automatic fluid reservoir bottle (pictured below - I bought by itself - not as part of a kit per se')
  2. Vacuum pump https://www.amazon.com/HFS-Brake-Ble...Braake+bleeder
  3. Speed bleeder valves (Russel #639630 on Amazon) You'll leave them permanently installed, so buy 4.
The installed Russel speed bleeder (check) valves do not leak air around the threads after backing them off of the seat; one of the PIA of the stock valves which accounts for more air and wasted fluid AND TIME than about anything else.
(Not pictured) is an inexpensive, hand operated vacuum pump attached to a catch bottle used to draw the old fluid and air from the speed bleeder valve.
A Mitivac reservoir bottle (pictured) clamps onto the reservoir(s) and keeps reservoir filled with fresh fluid level so that you don't accidentally suck air into the brake lines (or pump air in if pumping the brake pedal instead of vacuuming the old fluid out).
Oh! Forgot to mention: The front reservoir on the Master Cylinder serves the front brakes, and visa-versa. Good to know. (I had to draw air into my system before I realized that...)
If you are relegated to DIY projects, this stuff makes this (annual for me) chore a breeze! Of course, there are 'many ways to skin a cat', but if this helps anybody...mission accomplished!!
90 #1202
Sans secondaries
SW headers, X-pipe, MF muffs
Old 07-29-2016   #2
ZR-1 Franz
Default Re: Bleeding brakes - easy way!
I use this system since many years. It works fine. The other system
which works with pressure doesn't work, because the adaptors for the reservoir
of european cars don't fit tight enough with american cars So it is leaking.
This system is the best solution to do this job, especially im my situation.
Franz
ZR-1 Franz, '90 ZR-1 # 982 Red/Saddle (Manual
Control Air Conditioning)
ZR-1 Franz is offline   Reply With Quote
Old 07-29-2016   #3
Jagdpanzer
Jagdpanzer's Avatar
Paul,
Excellent write up
Vacuum pump link no worky https://www.amazon.com/kis_CUP_F8F73...E09/1469787857
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 07-29-2016   #4
Billy Mild
Does anyone know how to get the BRAKE light off? I think you need to bleed the brakes.
Looking for a ZR-1
1985 Yamaha RZ350-NOT STOCK
1971 Yamaha AT1-Middle of a restoration
Old 07-29-2016   #5
Mystic ZR-1
Mystic ZR-1's Avatar
I use an Army surplus blood transfusion machine
to bleed my brakes (no kidding...).Works great!
Easily draws 30" of vacuum and if I ever need an at home
blood transfusion, I'm ready!
Got it at a flea mkt for $20, wife thought I was nuts, she may
have something there...
I use it along with Speed Bleeders.
The sexy blue hoses we're my add, Uncle Sam's hoses
were all dried out.
Old 07-30-2016   #6
Paul,
Excellent write up
Vacuum pump link no worky https://www.amazon.com/HFS-Brake-Ble...Braake+bleeder
Fixed it...I hope!
Paul
90 #1202
Sans secondaries
Old 07-30-2016   #7
were all dried out.
Transfusion...for your CAR!
90 #1202
Sans secondaries
Old 07-30-2016   #8
Mystic ZR-1
Paul
Maybe fill one of those glass bottles with the
moonshine you had at BG last year?
That would be a TRANSFUSION!
