07-12-2008 | #1 |
Secondary relay module questions
There is a post on CF as well, but I had some questions regarding the module.
in that other post, someone said the module was used 90-92 and 93-95 did no and it was in the ECM.. since the replacement ECM is the same for all years (although Kurt's website only states 90-94) then couldn't the module be eliminated and the wiring/harness/ PROM be made to work without the Relay module? I am trying to understand the logic, if the 90 has the module, but I use a ECM that can be used in a 93 in my 90 and it works, I would think you could change something to eliminate the relay module if needed. Now I could be all wrong ont he relay module as I am going by what I read in another post..
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - 3" Magnaflow Bullet cats - LT4 Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
