10-04-2018 | #1 |
Startup Squeak
Don't know why, but it seems that as temperatures are dropping, initial startup of the cold engine brings w it a squeaking coming from the area of the serpentine belt, tensioner, and alternator. It goes away once the motor is warmed up and subsequent startups do not exhibit the same. The last time something like this happened, the alternator went out. Current alt is a reman'd Delco unit w fewer than 5K miles on it. I also did replace an older tensioner w a newer one.
Any thoughts?
10-05-2018 | #2 |
Re: Startup Squeak
Pull the belt off and start her up.
Frank Urbo. NCM Lifetime member # 982 Registry Founding # 237 |
10-05-2018 | #3 |
Re: Startup Squeak
squeak? does it squeak with every revolution or seem to? what balancer do you have?
When I had my 2007 Malibu had a startup chirp only when cold, meaning if I start it and heard the chirp, shut it off immediately and started it again no chirp. turned out in that case it was the balancer..
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - 3" Magnaflow Bullet cats - LT4 Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
10-05-2018 | #4 |
Re: Startup Squeak
Try relaxing the belt tensioner with the engine idling. Also check if the AC compressor pulley is making contact with the air horn hose clamp.
10-05-2018 | #5 | |
Re: Startup Squeak
Jeff, What about the balancer? This starts off quiet and as the motor warms up the squeak becomes louder and then slowly the squeak fades away as I drive the car and it warms up to operating temps. With the engine warm on restart, no squeak.
[SIGPIC][/SIGPIC]Former Membership Chairman Former ZR-1 Registry - BOD 1972 Corvette 4speed base Coupe SOLD long time ago 1984 Corvette Z-51/4+3 SOLD 1992 Corvette ZR-1 Aqua/Gray #474 SOLD 1992 Corvette ZR-1 Black Rose/Cognac #458 2014 Honda VFR Interceptor DX Last edited by XfireZ51; 10-05-2018 at 04:24 PM. |
10-06-2018 | #6 |
Re: Startup Squeak
Phil,
U hit it on the head. Started up today and squeak began to be more prominent. Took the butt end of a breaker bar and pushed on tensioner. Squeaking stopped. Let off, squeak came back. Good to know its not a bearing in the alternator or something like that. Aside, from replacing the tensioner (or should I bother) anything I can do to eliminate the squeak?
10-08-2018 | #7 | |
Re: Startup Squeak
Marc rebuilds the tensioners for $139 in one day. --Bob
10-08-2018 | #8 | |
Re: Startup Squeak
Wondering if I should have it rebuilt or replaced? Is the startup squeak a sign of impending problem?
10-09-2018 | #9 |
Re: Startup Squeak
I rebuilt the one on my 02 Z06. basically just remove the seals on the bearing, clean it up and repack with grease. it worked fine and the squeaking stopped.
[B]1990 #2815[/B] [COLOR="Red"][B]Red/Red[/B][/COLOR] Ported Plenum & IH (by Pete) Haibeck Chip Rebuilt FPR (by Phil) FIC Injectors Watson LT Headers 3" Stainless Works exhaust Lingenfelter Open Air Lid Bill B Built Transmission Shifter & C Beam Plates [FONT=Impact][COLOR=red]1992 [COLOR=black]#[/COLOR] 091[/COLOR][/FONT] [FONT=Impact][COLOR=#ff0000]Red/[COLOR=silver]Gray[/COLOR][/COLOR][/FONT] [B]SOLD[/B] |
10-09-2018 | #10 | |
Re: Startup Squeak
http://www.zr1specialist.com/HAT%20W...0tensioner.htm
