Go Back   ZR-1 Net Registry Forums > Corvette > Corvette Audio/Electronics
Old 04-12-2010   #1
todesengel
Default Speaker question
I am going to install a new dd mp3, gps, blah, blah head unit into my 1990 zr1, along with a powered sub. My question is, what speaker size is best for direct replacement in the rear and kicks? I plan on rewiring everything, except the antenna, power, ground, and constant, and leaving all other wiring intact, so it can be re-installed at a later date.
What say the experts here for the speaker replacement? I really do not want to modify anything where it cannot be put back to stock easily.
TIA.
note: yes, I did search, but there was nothing really definative to me.
todesengel is offline   Reply With Quote
Old 04-12-2010   #2
Default Re: Speaker question
hey there,
Which DD are you installing?
If you are considering a Pioneer Avic Z110BT or Avic Z3, both take minimal modification to the bezel to install properly.
Goldcylon and QB93Z have one installed as well.
Old 04-12-2010   #3
scottfab
scottfab's Avatar
Please take lots of pics as you do this.
I too am looking at the same issue.
Scott
Old 04-12-2010   #4
todesengel
I will do that. I am in process of putting a new stroker motor into my supra, and a twin k3 turbo's jz engine into the 78 280z, so this most likely will be a project in a couple of weeks. I can certainly do a writeup on my process though if it is desired.
Old 04-12-2010   #5
scottfab
scottfab's Avatar
A write up is fine. The interesting thing (to me) will be the look and if it is possible to keep the stock look as close as possible and/or the prospects to return to stock.
Scott
