Old 05-25-2016   #1
KJL
Default Rear Main Seal Question
In the process of upgrading my flywheel and clutch and though it would be a good time to also replace the rear crank seal and crank seal housing gasket. The question is would it be easier to replace the seal with the housing removed or bolted to the engine?
File Type: jpg IMG_20160319_175917845_zpskmlrvir0.jpg (216.7 KB, 19 views)
1995 ZR1 #159
Ported,Corsa,4.10 Rear, Dual Disc RAM Clutch, Alum Flywheel, Haibeck Chip, ZFDoc Plates, Relocated Battery 400 rwhp
1992 ZR1 #280
Ported, Locked Secondary's, Flowmaster Exhaust, Haibeck Chip, 375rwhp
1996 Collectors LT4 (Stock)
1972 Convertible 434 Small Block
572 rwhp
KJL is offline   Reply With Quote
Old 05-26-2016   #2
Jagdpanzer
Jagdpanzer's Avatar
Default Re: Rear Main Seal Question
Best to get a gasket from Jerry and replace the seal on the bench.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 05-26-2016   #3
KJL
OK Thanks, Gasket and seal just arrived from Jerry's.
1995 ZR1 #159
1992 ZR1 #280
572 rwhp
