Old 02-14-2014   #21
Z06scentair
Z06scentair's Avatar
Default Re: Headers Installation...
Im still trying to find a factory set to NCRS my car. Steve offered me his to use, but I would rather purchase a set to have with the car.
It's the only Item I need to make my car Original, but like my old man says their only original once!
Old 02-14-2014   #22
USAZR1
USAZR1's Avatar
What exactly are you looking for? I'll try to keep an eye out for it.
Clint & Sherry
1994 ZR-1 White/Red #152 (sold)
1991 ZR-1 Callaway Aerobody #1332 (sold)
1990 ZR-1 Red/Red #952 (sold)
2002 Z06 Torch Red/Mod Red widebody
USAZR1 is offline   Reply With Quote
Old 02-15-2014   #23
Z06scentair
Sorry Chuck not trying to hi-jack your thread.
Just need a full exhaust from a 1990 minus the exhaust manifolds.
Old 02-15-2014   #24
VetteVet
VetteVet's Avatar
I've got one from a 1991. Are they the same?
Jep
VetteVet is offline   Reply With Quote
Old 02-15-2014   #25
If ur looking for something after cats, an LT-4 exhaust should work.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 02-16-2014   #26
Schrade
Anyone with PE pipes think that the exhaust controllers at the end of the pipes can be remotely controlled? Jeff? Dave?
Electronically or by vacuum?
Old 02-16-2014   #27
Shrek
Pretty sure they offered that option when they were in business. Plus I believe the power capsules (mufflers) were used on many different applications other than vettes, so it might be worth a search.
Found this on the capsule itself! http://www.powereffects.com/tech.htm
Jeff
Shrek is offline   Reply With Quote
Old 02-16-2014   #28
Schrade
Spent :30 minutes getting 2 ex manifold bolts loose P side. Wow.
I found 2 ex manifold bolts missing on the 4-hole.
This is looking like a BIG job...
Old 02-16-2014   #29
Z06scentair
Chuck,
I will say while mine was on the lift a couple of months back, it appeared the header swap would not be a simple job.
You can do it though, I have confidence in you Pal!
Old 04-23-2014   #30
4-cam
Schrade
I just went through this. I certainly didn’t document the installation up to your standards though.
Many of the bolts are accessible easiest from under the car with long extensions. Have a good assortment of extensions, swivels, swivel wrenches and short stubby combo wrenches. I used my ΒΌ “socket set on most bolts as mine were not that tight or corroded. The Passenger side is easiest. DR side a bit more difficult. I had to loosen the heat shield and bend it a bit on the DR side to get all the bolts off. New Header installation is much easier.
Order a new dipstick tube gasket from Jerry if you haven’t already. My SW headers required that I make a dipstick relocation bracket. (I copied the basic design of Pauls bracket…. Thanks Paul!) I would bet your OBX headers will need it also.
If you or anyone else needs to reinstall the AIR tubes on your headers, I have a stick of 304 – 3/8 OD Stainless tube that I have left over from my installation. What a bit@# to bend.
Good Luck
Darby
[I]4-cam[/I]
[I]1991 ZR-1 Blk/Gry #31[/I]
[I]SW Headers/Xpipe- Dynomax Muffs[/I]
[I]Ported top end[/I]
[I]Secondaries Removed[/I]
Tune by Dominic
4-cam is offline   Reply With Quote
