Go Back   ZR-1 Net Registry Forums > Off Topic > Review/Evaluation
Old 01-11-2013   #21
sammy
Default Re: Drag radial test
craig , after the 60 runs i have made on these tires , i have found them to work the best at 23lbswarm. before your first run do a good 5 sec burn out . then every run there after you will only need a 2-3 sec burnout .any longer and the tires get oily. perfect temp according to nitt0 is 190 deg. enjoy . of also a good starting line rpm is 3000 .if you have a fidanza flywheel. do a controlled release of the clutch off the line .
Old 01-11-2013   #22
Good crib Brad!
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 01-12-2013   #23
HAWAIIZR-1's Avatar
Thanks for the tips and for sharing your experience with the tires, traction, and driving techniques.
"ZR-1 NO KA 'OI"
"ZR-1 ICHIBAN"
NCM Lifetime Member #2048
