Old 05-12-2017   #1
1991KOTH
Default Hissing noise after plenum pull
The car makes an odd noise when its cranking, then when it finally starts it idles up to 3000 then comes down. Hissing appears to be coming from front drivers side near the throttle body.
Also: The car is not taking anymore coolant after draining it. Ive tried jacking the car up on its side to burp the system, but only a few bubbles come out. Any help?
1991KOTH is offline   Reply With Quote
Old 05-12-2017   #2
Young1
Young1's Avatar
Default Re: Hissing noise after plenum pull
I can help you. I live in Ocala. I will pm you my phone number.
Old 05-14-2017   #3
Jim Stanley
My 90 ZR1 has a whistle when idling warm. My plenum was also recently R&R.
I would be interested to know what you find. Thanks!
Jim Stanley is offline   Reply With Quote
Old 05-14-2017   #4
Jagdpanzer
Jagdpanzer's Avatar
Hissing usually is a leaking plenum gasket. First try re torquing according to FSM procedure. If that doesn't solve it then try Jerry's thicker plenum gaskets which is what I did.
Phil Wasinger
1994 Torch Red ZR-1
George Braml Intake
Old 05-14-2017   #5
Jim Stanley
Thanks, I'll check it out!
Old 05-14-2017   #6
1991KOTH
Turned out to be a loose hose feeding into the plenum
Old 05-14-2017   #7
Jim Stanley
Thanks for that info.
Back in the day I would use a propane torch (unlit of course) to look for vacuum leaks. When the propane gets sucked in the rpm goes up a bit.
Has anyone found this to work on the ZR-1?
