07-30-2015 | #1 |
Interesting effect of valve coking
This was displayed in a thread on the C7 forum discussing issues w Direct Injection and effect of not having fuel sprayed on valves.
The dyno chart demonstrates the gradual loss of power over time. I suspect something like this may also happen if you're not using ur secondaries very often especially since oil fumes are quite present in the LT-5 air intake. The third and fourth run show difference in same motor after de-coking of valves. Fairly dramatic.
[SIGPIC][/SIGPIC]Former Membership Chairman Former ZR-1 Registry - BOD 1972 Corvette 4speed base Coupe SOLD long time ago 1984 Corvette Z-51/4+3 SOLD 1992 Corvette ZR-1 Aqua/Gray #474 SOLD 1992 Corvette ZR-1 Black Rose/Cognac #458 2014 Honda VFR Interceptor DX Last edited by XfireZ51; 07-30-2015 at 08:58 AM. |
07-30-2015 | #2 |
Re: Interesting effect of valve coking
07-30-2015 | #3 |
Also very interesting comments in this vid regarding effect of oil in throttle body
http://youtu.be/Mk4e5XFe47A
[SIGPIC][/SIGPIC]Former Membership Chairman Former ZR-1 Registry - BOD 1972 Corvette 4speed base Coupe SOLD long time ago 1984 Corvette Z-51/4+3 SOLD 1992 Corvette ZR-1 Aqua/Gray #474 SOLD 1992 Corvette ZR-1 Black Rose/Cognac #458 2014 Honda VFR Interceptor DX Last edited by XfireZ51; 07-30-2015 at 12:40 PM. |
07-30-2015 | #4 |
And, another video on YouTube is "Oil Catch Cans: Myth or Must Have?"
I'll save you some time... They're a MUST HAVE, especially high rpm as in WOT or engine braking. One of the (several) striking things I see as result of deleting my SPTs is the lack of coking on the intake valves; second only to steam cleaning. As also mentioned in the video (first one) the amount of oil ingested and thus coking (I surmise) is reduce by 90% as result of the oil level being down almost/about a quart. True, the motor in the video was a modern LT1 w/ dry sump (read: different animal), but this is also true of the LT5s far as oil dumping into my catch can when the dipstick level is at the FULL line. Windage/frothing is probably the culprit. So, I wonder what harm there is to maintaining the oil level as some point below the "FULL" line; say at the bottom 1/3? Or, should I not worry about it, being fooled into thinking all is well because I have a catch can in place (on my 90, at least, and soon on the 91 too)? I'm leaning in favor of the catch can. I guess the question is, just how efficient is it, i.e., does it capture just a token amount of oil, or is it really very practically removing it "all"? Which can(s) are most effective?
Good carz, good food, good friendz = the best of timez! 90 #1202 "FBI" top end ported & relieved Cam timing by "Pete the Greek" Sans secondaries Chip & dyno tuning by Haibeck Automotive SW headers, X-pipe, MF muffs Former Secretary, ZR-1 Net Registry Last edited by Paul Workman; 07-30-2015 at 10:52 AM. |
07-30-2015 | #5 |
Justa point of clarification
The dynos are of a BMW 3 series, not LT1, but its indicative of a motor w DI.
