11-07-2014 | #31 |
Re: Boosted LT5's
I'm planning to build a single rear mount turbo for my Z in two years. Currently gathering data and knowledge before executing. I have so many ideas that are out of the box and you will not notice it up front, it will be hidden.
I would do it sooner but I am currently out of country, which means I have a lot of time to plan and research.
Tony Davila (Projects) Water Meth: http://www.zr1.net/forum/showthread.php?t=19422 Exhaust cut outs: http://www.zr1.net/forum/showthread.php?t=22689 Auxiliary 12V install: http://www.zr1.net/forum/showthread.php?t=22878 Auxiliary pusher fan install: http://www.zr1.net/forum/showthread.php?t=22859 Oil Catch can Project: http://www.zr1.net/forum/showthread.php?t=20320 |
11-07-2014 | #32 |
Re: Boosted LT5's
Tony,
Great to hear this new upgrade of yours and can't wait to see the progress! I'm hoping to have 600hp in the coming weeks myself! David |
11-07-2014 | #33 |
Re: Boosted LT5's
What are you doing to get there? Thats quite a bit more than stock.
11-07-2014 | #34 |
Re: Boosted LT5's
flux compacitor?
11-07-2014 | #35 |
Re: Boosted LT5's
11-07-2014 | #36 |
Re: Boosted LT5's
David, is the build underway?
11-07-2014 | #37 |
Re: Boosted LT5's
11-07-2014 | #38 | |
Re: Boosted LT5's
ed ramos #3028 |
11-07-2014 | #39 |
Re: Boosted LT5's
Ed/come ride in my t turbo fidanza corvette/w lingenfelter motor/the only lag is until you let up and let the tires get traction/ls3 417cu/
11-07-2014 | #40 | |
Re: Boosted LT5's
Your big cube small block already has torque without the turbos so lag will not be present. I have seen some mustangs run staggered turbos one small one and a large one totally eliminate lag even in small cube engines. I bet your car hauls big time. ed ramos #3028 |
