03-27-2024 | #1 |
Instrument panel cover replacement
The plastic cover, for lack of a better description, over the instrument panel on my '93 is fogged up in the center. It looks like somebody probably tried to clean it with something that scratched or otherwise damaged the plastic. Does anyone know how involved it is to replace it, and where there may be a source for a replacement?
03-27-2024 | #2 |
Re: Instrument panel cover replacement
03-27-2024 | #3 |
Thanks, I will!
03-27-2024 | #4 | |
03-27-2024 | #5 |
Thanks for the link! I appreciate all of the help.
03-27-2024 | #6 |
03-27-2024 | #7 |
03-27-2024 | #8 |
You could also try to polish it back to clear
03-28-2024 | #9 |
03-28-2024 | #10 |
I drop my steering column when I need to take the cluster out. No need to mess with the airbag.
JOHNNY P Currently own 90 ZR-1 #845 DRM 500 engine package 90 #226 Might be a parts car not sure yet |
