Old 07-22-2015   #1
csavaglio
Default Housecleaning Misc C4/ZR-1 Parts
With the garage spot that the steel blue car occupied now open, I'm clearing out some of the things I've collected with it. Prices include shipping USPS priority unless otherwise stated. If you're local, I can lower the prices accordingly.
$20 Haibeck Antenna Ground upgrade kit, brand new, never used. Updates the older car's antenna to the later C4 with a ground to get much better reception.
$100 Sport Seat leather, black, complete (bottom, back, L/R bolsters. 1991-1993 style. Excellent shape with no visible wear at all. Passenger side seat bottom, but the seat back and bolsters are fine for either side. Would be good if your driver seat back or bolsters needs replacing.
I have a 1991 blue tinted top. The frame is in excellent, near new condition, but the lens is cracked. I don't believe this was ever mounted on the car and probably cracked from being left in the back of the car on hot days. The decal warning of this is even still on it. $150 also for local pickup.
**SOLD** I also have a set of factory 1991 ZR-1 sawblades in excellent driver shape......$800 but I don't want to try to ship them, so they'd be local pickup in Colorado only.
***SOLD*** $300 Complete 1991 Pizza Box, complete including brass key chain. Coffee table book is still sealed. Minor wear on box and vhs tape case.
***SOLD*** $100 1991 Corvette FSM, Red cover, both volumes complete with no missing or destroyed pages. Has some wear and cover is torn a bit at the spine, but perfect for those of us that use it to work on the their cars.
***SOLD*** $30 1990-1993 LT5 Service Manual Supplement, slight wear, has somoene's name written on the cover, but the insides are in excellent shape.
***SOLD***$50 Power Antenna, complete power antenna/motor from a '96 with 38k miles. Has the later ground wire, so it could be used to upgrade the older cars or replace a broken one. Wiring, grommet, rubber moisture cover, etc are all complete and in great shape. Also includes bracket.
***SOLD***$125 C4 Clutch Master Cylinder and Slave, rebuilt by Jim at Power Torque, this is the original pair from my 1991 ZR-1. Slave is in perfect shape and MC has some paint flaking on the lower part. I don't think it'd be visible installed or could be easily touched up.
***SOLD***$50 PKE remote, from my '96. Needs a new battery after sitting in a drawer for a while, but worked perfectly when I tried it last. Minor wear on the case and on the buttons.
***SOLD***$10 Wheel Lug Covers, silver, complete set of 20, dirty and may not clean up perfect. I'd say driver shape or to replace cracked ones.
***SOLD***$5 Cigarette lighter, looks like it may have been used once. Excellent shape
***ALL SOLD***$5 each Ash Trays, for some reason, I ended up with 3 of these. One is dirty but will clean up fine, the other two are very nice.
***SOLD***$5 Original Radiator Cap, Delco, 16lb, bare metal cap. Very good shape. I believe it works fine and could be used for judging.
***SOLD***$5 Skip Shift eliminator plug seal kit, still sealed, never used.
***Sold***$175 LT5 Plug wires, complete set including wire separators and the corrugated heat shields. Red, numbered for each cylinder, with LT5 on them. They are very clean and look nearly perfect.
I think that's everything for now.
Chris
csavaglio is offline   Reply With Quote
Old 07-22-2015   #2
carter200
carter200's Avatar
Default Re: Housecleaning Misc C4/ZR-1 Parts
Chris,
I'll take a very clean ash tray and the radiator cap. Paypal ok? Lat me know, thanks.
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
ZR1NET Founding Mem #155
Old 07-22-2015   #3
Demps
Demps's Avatar
Chris,
Slave, master--if both rebuilt by Jim.
PKE, skip shift seal.
Ted
Old 07-22-2015   #4
G8nightman
G8nightman's Avatar
$100 Sport Seat leather, black, complete (bottom, back, L/R bolsters. 1991-1993 style. Excellent shape with no visible wear at all. Would be good if your driver seat needs replacing.
Any pics?
90 Chevy ZR1 LPE #2315 'SOLD'
90 Chevy ZR1 LPE #2774 'SOLD'
91 Chevy ZR1 #1512
91 Chevy ZR1 #951
95 Chevy ZR1 #338 'SOLD'
91 BMW 850i
94 BMW 850csi
95 BMW 850csi
94 Lotus Esprit S4
07 Benz CLS550
06 BMW M5 "SOLD"
G8nightman is offline   Reply With Quote
Old 07-22-2015   #5
carter200
carter200's Avatar
Chris,
Paypal sent. Thanks......
95 ZR-1
BLK/Gry
#392
LT5 Reg# 868 *RIP*
Old 07-22-2015   #6
Demps
Demps's Avatar
Originally Posted by carter200 View Post
Chris,
Ditto
Old 07-22-2015   #7
What does this consist of?
Watson Headers (2" Primary) - 3" Magnaflow Bullet cats - LT4 Catback
Old 07-22-2015   #8
csavaglio
It's some wires and connectors to ground the antenna assembly. It's a recreation of the kit GM put out as part of a TSB for it. I'm at work for the night, so I'm working off memory. I'd have to look at it again to see what else it comes with when I'm home.
Demps and Carter, I got your payments. I'll send the parts out in the next day or two. Thank you!
Chris
Old 07-22-2015   #9
ZR wun injuneer
Would like to get the ashtray(s) and cigarette lighter, Lug nut covers, and power antennae. Let me know the total so that I can send payment by paypal.
C.B.
ZR wun injuneer is offline   Reply With Quote
Old 07-22-2015   #10
csavaglio
PM sent.
Chris
