04-13-2008 | #1 |
where can i get the 10-60 castrol in so cal and can i use...
4-30 mobil one in the interim? or sould i use only gm synth. 5-30 trans oil . i have on the shelf some royal purple sncro max tranx fluid would that do until i get the castrol? your thought very welcome
04-13-2008 | #2 | |
Re: where can i get the 10-60 castrol in so cal and can i use...
04-14-2008 | #3 |
I switch between the GM synchromesch fluid and the Castrol/BMW/M5 10-60 stuff. But I do mine every winter, so say at less than 10k intervals. If I get close to 10k then I start to think about changing it again.
I find that the GM stuff, (I forget the p/n's) as the original GM stuff is superceeded by the fluid you buy @ dealer now, seems to take less warm up time than the Castrol oil. I bassed my change interval on the results of a lubricity test zfdoc.com did on both oils....@ 12k the lubricity falls to about 40% of new oil....therefore using that info I do mine at or before 10k/1 yr intervals. JMHO Tom
04-14-2008 | #4 |
I'd think in SoCal there'd be a BMW dealership on every corner...
04-14-2008 | #5 |
I was hoping i could get it somewhere else . i get a rash if i go near a bmw dealership
04-14-2008 | #6 | |
04-14-2008 | #7 |
I'll get a big bottle today ,thanx dominic . good call
04-14-2008 | #8 |
From my understanding BMW is the only importer of that weight oil, so you're stuck dealing with them. The TWS is apparently the oil of choice for their M-series class of cars. I can't imagine paying 9 bucks a liter for an oil change. You gotta pay to play I suppose.
04-14-2008 | #9 |
www.zfdoc.com
he has it & no rash |
04-15-2008 | #10 |
thats a whopping 18 dollars a year for a trans fluid change...i bet some guys here spend more than that on beer every w-e
bj |
