Old 05-04-2017   #11
Default Re: Forced Air Induction.....(maybe)
Originally Posted by Top Toy View Post
They look great but actually hurt power compared to an open filter lid. Too much pressure drop thru the small opening and the hose between the bumper and air filter.
Sent from my XT1254 using ZR-1 Net Registry mobile app
I agree only the tube that connects the lower part of the filter contacts the filter by 30%. It's a large choke point. The best part of the system is the front diffuser plate and its aggressive look. That's about it.
Old 05-05-2017   #12
I agree only the tube that connects the lower part of the filter contacts the filter by 30%. It's a large choke point. The best part of the system is the front diffuser plate and its aggressive look.That's about it.
This has been proven many times over.
Frank Urbo.
NCM Lifetime member # 982
Registry Founding # 237
Old 05-05-2017   #13
+1 from me too. Corey & I dyno tested my 415 at his shop & came to the same conclusion. Scratch the forced air system.
In addition, we found no verifiable difference between a paper filter & the filter being completely removed. So much for the K&N myth about added horsepower. K&N is not worth the cost & cleaning hassle for a filter that has no benefit save for being reusable.
Old 05-05-2017   #14
S.hafsmo
S.hafsmo's Avatar
I've seen tests where k&n type filters let through 18 times more dirt than a paper insert, as well as clogging 4 times faster. Not a good investment.
- '90 ZR-1
S.hafsmo is offline   Reply With Quote
Old 05-05-2017   #15
Ive used K&N but Marc H recommended use of paper element which I have now switched to.
Former ZR-1 Registry - BOD
1984 Corvette Z-51/4+3 SOLD
2014 Honda VFR Interceptor DX
Old 05-05-2017   #16
ABBEZR1
I agree with you all and I wouldn't pull the trigger on one for a mod for horsepower one of the previous owners did on my car and I really do like the aggressive look that it gives the car. IMO... You really are making me wonder(and maybe the original poster) can you have the best of both worlds?? Can I leave the diffuser and do a open lid system? Just something to think about if you like the looks but want to get rid of the choke down point...
Steve,
_______________________
1990 Bright Red/Black #946
B and B X-Pipe
Stainless Works Long Tube Headers
Cat delete
49th Street Rockers
Haibeck Chip and Tune
ABBEZR1 is offline   Reply With Quote
Old 05-13-2017   #17
rkreigh
most of the fancy intake stuff is eye wash that doesn't do anything for power
I tested a clean paper element and a k&n back to back and there wasn't any difference.
Graham said the factory stuff was good up to over 750
I haven't ever tried running the car without the air filter (and probably won't) but I can't imagine that it's much of a restriction
I saw the fancy jeal stuff and loved it, but it's made out of unobtanium now and I don't know if it works better than stock
not much power left on the table with stock so if it ain't broke......
95 390 LPE ZR1 (505 rwhp)
Old 05-15-2017   #18
Hog
I've seen evidence of this on my MAF(Mass Air Flow) equipped vehicles. I always find a very fine gritty coating on those fine MAF wires. You know, the wires that are supposed to stay clean as the electrical resistance across them is measured as a function of airflow. Not impressed. K&N always used the selling point that their air cleaners were used on the turbine engines on the M1A1 Abrams Main Battle Tank during the Desert Storm/1st Gulf War. Of course the turbine induction and out Chev engine air intake designs aren't comparable, but I do remember the old K&N ads.
These aftermarket air intakes may sound nice, but power claims are inflated on N/A engines. There are some nice powergains on OEM forced inducted engines, as superchargers are esp. sensitive to pre blower restrictions.
I did some at the track installations of some K&N Fuel Injection Performance Kits. Performance increases ended up being greater as the humidity/temp dropped as the night progressed, over any sort of power gain from the air intake/filter difference.
peace
Paul
Old 05-15-2017   #19
Ditto for my cars. K&N was a pain to clean and oil and added no benefit. Used the standard AC Delco filter and removed it when racing. -Bob
