Go Back   ZR-1 Net Registry Forums > C4 ZR-1 > C4 NCRS for ZR-1s
Old 09-11-2019   #1
Joelbbvette
Joelbbvette's Avatar
Default 1991 ZR-1 Owners need Help
Can those of you with stock 91 wheels let me know if you have your LTPWS label on the outside of the rim lip (Perpendicular to road) or on the flat part of the rim (parallel to the road). Please include VIN number(last 4 digits) and is one end of it lined up with the lug nut one away from the valve stem clockwise?
Thank you.
Joel
Joel
Tampa/Rockledge, FL
Present Collection
1969 350/300 AC Convertible
1972 454 Coupe 2nd Owner
1988 KOH EX5006 - ZR-1 Prototype
1990 ZR-1 #277 NCRS Dave McLellan Award 2019
1994 Copper Convertible NCRS Dave Hill Award 2012
2001 Z06 122k miles
Joelbbvette is offline   Reply With Quote
Old 09-13-2019   #2
dandt67
Default Re: 1991 ZR-1 Owners need Help
Joel
Believe the slightly worn labels that were on my stock 1991 wheels were original to the car. I applied new labels in the same position as the original ones. They are on the flat part of the rim, forty five degrees counterclockwise from the valve stem on all four wheels. Have highlighted center position of the label with a blue piece of tape. Photo attached.
Car is 1470.
Hope this helps
Dan
dandt67
1991 ZR-1 Quasar Blue #1470
2016 Z06/Z07 Long Beach Red Tintcoat
dandt67 is offline   Reply With Quote
Old 09-13-2019   #3
DRM500RUBYZR-1
DRM500RUBYZR-1's Avatar
I have never seen them differently.
Marty
Old 09-14-2019   #4
Joelbbvette
Dan and Marty,
Thank you and yes it does help. I have seen an early 91 at Nationals with the early style of LTPWS on the side of the rim, they were original. Yours is the second design. So we know there was a running change now, just not certain where.
Hopefully some more folks with lower VINs will chime in of their style and locations. Crazy project has turned into the mystery for me and I'd like to help figure it out. Appreciate everyone's help.
Joel
Joel
Tampa/Rockledge, FL
Present Collection
2001 Z06 122k miles
Old 10-23-2019   #5
Joelbbvette
TTT can any other early 91 LTPWS cars please respond?
Thank you,
Joel
Joel
Tampa/Rockledge, FL
Present Collection
2001 Z06 122k miles
Old 01-16-2020   #6
Joelbbvette
TTT can I please get some more responses on the early 91s, prior to car 1470.
Joel
Tampa/Rockledge, FL
Present Collection
2001 Z06 122k miles
Old 02-03-2020   #7
mrand
I keep forgetting to check #1334. Posting here in hopes of reminding myself :-)
Marc Randolph
1991 #1334 Blk/Gray
mrand is offline   Reply With Quote
Old 02-03-2020   #8
Stingray1967
Stingray1967's Avatar
Are those stickers still available somewhere?
1967 Corvette convertible, L79, 4 speed, red / black / white top
1994 Corvette ZR-1, white / black
NCRS North Central Chapter Judging Chairman
Stingray1967 is offline   Reply With Quote
Old 02-04-2020   #9
mrand
Apparently the early cars had GM Part 10074342, which was curved to go on out outer-most part of the rim. They are rare. Someone talked about reproducing them a few years ago (maybe Joel?).
It was replaced (approximate VIN TBD, per this thread) with a rectangular label, using 10180847 for the fronts and 10180848 for the rear wheels.
http://oemcats.com/oem-parts/10180847.html shows some stocking dealers, and Kurt White's site has them (read elsewhere about caveats). Probably others floating around.
Marc Randolph
1991 #1334 Blk/Gray
Old 02-04-2020   #10
Stingray1967
It was replaced (approximate VIN TBD, per this thread) with a flat label, using 10180847 for the fronts and 10180848 for the rear wheels.
http://oemcats.com/oem-parts/10180847.html shows some stocking dealers, and Kurt White has them. Probably others floating around.
Is that $15 per label I wonder?
