10-07-2015 | #1 |
Clutch Out, Which Should I Buy?
So clutch is slipping in gears 3 and up.
If I'm going to change it I'd like to do it all; FW, clutch kit, short throw shifter, headers. Looking at 1. 198551 Fidonza FW - 350$ 2. DF930140 Centerforce - 675$ 3. ZFdoc lockout shifter - 250$ 3. Maximizer headers - 500$ 4. Henderson tune -300$ Anyone have an opinion on the parts? Thanks! Jay
1991 White ZRJuan #1616 Mileage: 56K Sept-14 -- 113k May-18!!! God Damn I Love This Car! |
10-07-2015 | #2 |
Re: Clutch Out, Which Should I Buy?
If there hasn't been a significant increase in power from stock, the LT-1 Camaro clutch disk and stock pressure plate work just fine. Hurst short throw shifter is also a less expensive alternative.
10-07-2015 | #3 |
Recommned the ZFDOC shifter is worth the extra money
10-07-2015 | #4 |
I don't think i've ever just replaced a disk before. Thats okay?
10-07-2015 | #5 |
I definitely want to keep the stock reverse lockout. Always here good stuff about ZFDoc.
10-07-2015 | #6 |
If you're not drag racing it you can go with the l98 or lt1/4
10-07-2015 | #7 |
??? I thought the splines on the ZF for a ZR-1 were different from a base Corvette ZF??
10-07-2015 | #8 |
Don't play games with 30-year-old technology. Go right to Jerry and buy the ram dual disk setup. You won't be disappointed.
As for the short throw shifter, it is a preference. A good driver will get through the gears equally as fast. You will be able to sell your flywheel, Slave cylinder, throwout bearing and clutch fork. 400.00 worth of parts. Or you can do like I do and give them away to members that need them. http://www.jerrysgaskets.com/clutch-...nic-89-92-0d1/
Robert J. DeMarco [SIGPIC][/SIGPIC] [COLOR=blue]G[/COLOR][COLOR=red]rand[/COLOR] [COLOR=blue]S[/COLOR][COLOR=red]port[/COLOR] Registry Lifetime Member NCM Lifetime Member #2655 Pacecar Registry Member [COLOR=red]ZOOM Charter Member - ZR-1 Owners of Michigan[/COLOR] [COLOR=plum][I]ZR-1[/I] Registry member since 2012 [/COLOR] [COLOR=black]1990 LPE "368" Aerobody ZR-1, Last ZR-1 built by John[/COLOR] 1991 Callaway Aerobody ZR-1, DRM 500 1991 Shinoda Aerobody Spyder, 1998 Pace Car |
10-07-2015 | #9 |
The flywheel bolts are different we need shorter
10-07-2015 | #10 | |
