04-14-2017 | #1 |
C4 no flex stiffener at the track
pSometime ago i was asked if the C4 no flex frame stiffener helped with
launching my car when i drag race. After i installed stiffener i could jack up one side of car and still open both doors.Now it dose control twist and cowl shake, but no information if it would help drag racing. Well i my case i believe that it has helped (see pic) the car launches hard and straight without any twisting of cars frame. Now my car runs good and the frame stiffener has helped , but there are a lot of other things that make it run so good. The car leaves good, but weight transfer was not the best it could be.I tried disconnecting the front shocks fx3 (remove el connection) and that helped. When i tried to do the same to the rear shocks found one that was broken (no stop when gear is turned). My 60ft times then were 1.74 to 1.78. So i removed the fx3 system from car and installed QA'1s single adjustment shocks front and rear. The car now lunches harder and comes up without any body/frame flex. My 60 ft times are now 1.64 to 1.70 with this cooler weather? ( 68-74 deg with humidity between 42-56%) . Also being at almost at sea level with good track prep makes a big difference.The car will slow down when it gets warmer this summer. So right now the car is set up with QA1's front and rear, rear tires are M/T 315-35-17 S/S at 25 lbs. The 4L8OE transmission has a trans-brake from jakes transmission installed. The brake is called D3 with forward shift pattern. When i set trans-brake , i leave at 2600 rpm in 1st (shift\ lever in 3rd) the trans controller shifts at 6500 rpm at WOT from 1st to 2nd to 3rd. I race 1/8 mile so i do not have to shift at 7000 rpm, shifting lower puts "less" strain on most of the drive train parts. A lot racers and spectators ask is that a real ZR-1 and remark you don't see many Zr-1's on the road let alone at the drag strip. John //www.zr1.net/forum/picture.php?albumid=363&pictureid=3139 Last edited by aafc; 04-14-2017 at 01:32 PM. Reason: pic won't post have to wait for it come in the mail |
04-14-2017 | #2 |
Re: C4 no flex stiffener at the track
Looks like a strong launch (to my untrained eyes).
Which style brace? The X-brace? Or the V2V bars? |
04-15-2017 | #3 |
Thanks, i used the v2v bars.
John |
04-15-2017 | #4 |
04-15-2017 | #5 |
I'am having trouble posting pic from 4-9-2017. If you go to personal racing
stories "Titled hard launch at the track" to see the car from March 2017. John |
04-15-2017 | #6 |
04-16-2017 | #7 |
OK lets see if this works This shot taken at Orlando Speed World on 3-19-17.
This photo (proof) taken on 4-9-17,notice that car does not come up as much in this photo. I reset front shocks to 4 clicks to help keep the front down. John |
04-16-2017 | #8 |
What times does it run. Launches like my GS I converted to a auto.
1994 ZR-1 #198, sold [img]https://live.staticflickr.com/65535/48400173802_2a6f122cfb_n.jpg[/IMG] [COLOR=RoyalBlue]96 GrandSport#857[/COLOR],[COLOR=Red]Red Gut[/COLOR] 397 LT4, AFR heads,3:90 gears, DRM longtubes, Sepanek 700R4, Yank 3600, bla-bla... Best ET w/396 & 6-speed 11.02 @126.57 w/1.60 60' Best ET w/396 & 700r4 10.82 @124.87 w/1.48 60' 2003 DarkShadowGray Ford Lightning 460rwhp/550rwtq 12.11 @112.18 w/1.71 60' |
04-18-2017 | #9 |
Thanks for sharing John!! Just friggin awesome photos too!!!!!
04-18-2017 | #10 |
Nice times, My times are a bit slower. Best 11.541 @ 117 (43-53 deg) day
with hum @ 42%. Not a dedicated race car or daily driver just for fun! 1990 Zr-1 up graded to 368 cu.in. with stage one cams 525 hp at crank puts 418 RWHP, about 353 RWTQ, work done by SGC back in Jan. 2009. When the weather gets warmer in FL. it will run high 11.70's to 11.85 at the track. Do you race at maple Grove? I quit racing my dragster ( B/ED "RED BARON" back in 1988.Now that was a ride best pass 7.48 @ 175.45. I worked at Raceway Park Old Bridge N.J. back in 1968. John |
