#71 | |
![]() Join Date: Nov 2007
![]() So...it shouldn't be a biggie to bypass the control and activate the secondaries or "latch" the secondary system to always be on. It will (in the case of Marc's chip) require a modification (by him) to accommodate the second injector being on at idle (Marc's chip runs only one injector at idle). P. |
#72 |
When the secondaries are removed, does the purge solenoid (the one with the red connector) need to remain under the plenum, or can it be removed with the other solenoids?
#73 |
How much is the chip required for the secondary change???
#74 | |
![]() Join Date: Dec 2003
No,does not need to remain. or Yes,it can be removed. Pete
#75 |
#76 |
On the 91 what exactly can be removed? The spide,r the purge solenoid obvisouly the vaccum secondary actuators. Does the 91 require the underside ecm plug?
#77 |
I am still running the purge solenoid, since I don't like a car that smells like gas on a hot day... But if you wish to remove it I don't think the ECM will care.
The sensor under the ECM just has its vacuum line unplugged/removed, the electrical connection remains. Under the plenum, the vac storage canister, the secondary solenoid, and of course all the secondary hardware, is all removed. Vacuum pump is also removed. |
#78 |
corey did mine different . i have a rubber vac line from map sensor under the ecm to my vac pump . said they did thid on the bonniville car so the secondaries didnt shut down on the long bonniville runs .4 miles in think
#79 |
![]() Join Date: Dec 2012
Does an emissions chip retard the timing substantially?
#80 |
i think it's around $250 if you have marc do it
