#61 | |
#62 | |
Everything fit well? No issues? ![]() David |
#63 | |
![]() It actually took a bit longer than 15 minutes (It took about an hour to get to the passenger side 02 sensor plug) ![]() It is a very clean installation with the Air Induction system gone out of the way. I am guessing Stainless Works did some home work in the last year and solved ALL the issues. I would say the original stock exhaust system was ten times harder to remove than it was to install the SW ZR1CORVOR headers and SW ZR1CHAMSW 3 inch exhaust system ![]() Last edited by Dynomite; 01-01-2010 at 10:15 PM. |
#64 |
Removing the original exhaust system is a lot easier if you have a 3/8 inch swivel, a set of flex metric ratchet wrenches, and a set of 3/8 inch wobble extensions
![]() A set of 3/8 inch metric sockets and 3/8 inch socket wrench is obvious ![]() I use the wobble extensions on almost everything. Sears has them all......along with the 17 mm transmission plug allen wrench ![]() Last edited by Dynomite; 01-08-2010 at 08:34 PM. |
#65 |
#66 |
![]() Join Date: Dec 2004
Cliff,
first, congrats on doing the headers! ![]() Second: The "wobble" extensions, are they the one's that look like a C/V joint vs a U-joint......yea, my tool collection is that old, I have a rail of snap-on u-joint sockets that I bought back in '77 for working on my 72. ![]() TIA ![]() Tom
#67 | |
The wobble extensions are in second and third pictures and flex ratchet combination wrenches in fourth picture. You will notice what allows the wobble in the third picture. There are all sorts of swivels and swivel socket combinations you can get but these four tools/tool sets will get er done assuming you have a good 3/8 inch socket wrench and set of metric sockets. Oh...ya...you might need a good 1/4 inch and 3/8 inch torque wrench also. I like the ones that trip at your torque setting. And.....a good set of allen and torx wrenches. . ![]() ![]() ![]() ![]() Last edited by Dynomite; 04-14-2013 at 10:50 AM. |
#68 |
Thanks Tom.
I have to say...looking at all that heavy steel I took off including CATS, exhaust manifold, exhaust pipes, mufflers, air injection it is amazing how cluttered it was. And all that exhaust had only one joint actually consisting of two sub joints behind each CATS. What a tangled mess. And....those CATS are gigantic ![]() Those air injection tubes on the headers and going under the oil pan are unsightly extras which apparently are there only for starting a cold engine. This includes all that air injection stuff that went forward to a point under the drivers side headlight ![]() Now the SW headers/exhaust are very light weight, independent, and very clean with very smooth curves and several smooth joints and BIG straight pipes from start to finish ![]() Also the SW headers and SW exhaust come with some very nice chrome pipes (four) that are exposed out the back ![]() Last edited by Dynomite; 01-10-2010 at 01:29 AM. |
#69 |
Cliff, I hear you about the "tangle of piping" that the AIR system represents. It is a mess & ugly at that! That is one of the reasons my SSW headers are still in the box in my living room. Where I live the smog police will not pass a car without it's OE smog equipment....no emission inspection, no registration, no plates, no play. Until I get those tubes installed I can't put mine on.
![]() Thanks for answering my Q about the sockets. Yea I have a set in 3/8" & 1/4" of the u-joint kind. A friend of mine that is a dealer tech has a set that use the c/v joint principal....they are sweet, real smooth and you can do some extreme angles of attack without them binding. ![]() Tom
#70 | |
![]() In SD no one even looks at the car or truck for anything and licensing is dirt cheap ![]() If I had to add Air Induction to my SW headers it prolly would be less sightly to come into each header (with the smallest tubes that would pass emissions) from underneath between the engine and header (again....I think the Air Induction system is only for cold starts and the Air Induction valve is only open on a cold engine and since your engine is warm at emmisions checking....should be no emissions issue without that system....unless of course there is a rule on modifications and the emissions inspectors know a bit about what is or is not on stock Zs). Having to modify those clean looking headers would be a BIG bummer for me ![]() Last edited by Dynomite; 01-10-2010 at 09:47 AM. |
