07-25-2014 | #41 |
Engine (LT5) Temperatures on Hot Days
The Bottom Line Question for any discussion regarding Effectiveness of LT5 Radiators/Cooling Fan Systems is How do the Radiator/Fans Cool the LT5 Engine with AC On at 100 deg F Ambient Temperatures while idling in traffic.
Using HVAC Display for Engine Coolant Temperature Let us assume for simplicity that LT5 engine cooling is about the Radiator Air Flow and Radiator Coolant flow (as 5ABI VT and Goldcylon suggests). Lets further assume that the engine sensors, heat generation, spark advance, compression, load are identical between engines at a certain engine speed and ZR-1 speed in other words nothing to consider other than the air flow, coolant flow, and coolant temperature from the HVAC Display (AC ON and AC OFF). I am going to do some testing to verify exactly how two ZR-1s here in CA (90' with stock radiator and 91' with Ron Davis radiator) behave at 100 deg ambient temperatures (stop and go and on freeway at various speeds). I will determine exactly what the coolant temperatures are at 60 mph and 2,000 engine rpm in 5th Gear (including the worst condition idling with ZR-1 not moving). The Conditions I have are a 180 deg F Thermostat and Fans ON at 205 deg F and OFF at 200 deg F running on 91 Octane Fuel (Marc Haibeck Chip). Since this discussion was about Fluidyne Radiators, it would be interesting to see how the Fluidyne Radiators Cool the LT5 under the same conditions of 100 deg F Ambient Temperatures. That would then say something about the Stock Radiator, Ron Davis Radiator and Fluidyne Radiator effectiveness in cooling the LT5. I am thinking ALL radiators function well at ambient temperatures around 90 deg F and lower.....it is the 100 deg F ambient temperatures that are of issue. Using HVAC Display for Engine Coolant Temperature Water Pump, Coolant Temperatures, and Coolant Coolant Characteristics (Mix, Pressure, Elevation) A. Experiment Number 1 1990 Fans On 205 deg F Fans Off 200 deg F Stock Radiator 100 deg F Ambient at least 50% Coolant Mix AC On 72 deg AC Fan 7 Cruise 60 mph 5th HVAC temp 220 deg F (after exceeding that temperature during the idle test) (this was interesting because once the temperature came down to 204 deg F with AC Off the temperature did not rise above 205 deg F with AC On) AC Off 60 mph 5th HVAC temp 204 deg F and dropping slowly Fans are Controlling Coolant Temperatures when AC is Off AC On 72 deg AC Fan 7 Idle (not moving) HVAC 235 deg F and climbing (idle for 5 minutes) Coolant Temperature would keep climbing if I did not turn AC Off within a few minutes AC Off Idle (not moving) HVAC 230 deg F and dropping slowly Coolant Temperature CAN BE CONTROLLED by Turning AC Off B. Experiment Number 2 1990 Fans On 205 deg F Fans Off 200 deg F Stock Radiator 90 deg F Ambient at least 50% Coolant Mix AC On 72 deg AC Fan 7 Cruise 60 mph 5th HVAC temp 205 deg F AC On 72 deg AC Fan 7 Idle (not moving) HVAC 228 deg F (idle for 10 minutes) Coolant Temperature is stable at 228 deg F with AC On with Ambient Temperature 90 deg F In Summary From this experiment at 100 deg F and 90 deg F Ambient Temperatures the 1990 ZR-1 with stock radiator and Marc Haibeck Chip controlling the fans On at 205 deg F and Off at 200 deg F the following results were obtained......... 1. The Fan thermal switching control the Coolant Temperature (100 deg Ambient) when moving with AC Off (With AC On the Fans are always On). 2. At 100 deg Ambient Temperatures the 180 deg thermostat is not a player staying open under ALL conditions. 3. At 100 deg Ambient Temperatures the Coolant System FAILS when idling in traffic or at stop lights for over 5 minutes with AC On. 4. Excessive Coolant Temperature at Idle with AC On can easily be controlled by turning the AC Off. 5. It also was determined that if the Ambient Temperature dropped to 90 deg F the 1990 ZR-1 can idle in traffic at a stop indefinitely with AC On. (For those not having the Marc Haibeck Chip the Fan Controlled Coolant Temperatures in this experiment would be 234 deg F). Next the 1991 ZR-1 with Ron Davis Radiator C. Experiment Number 3 1990 Fans On 205 deg F Fans Off 200 deg F Ron Davis Radiator 100 deg F Ambient at least 50% Coolant Mix B. Experiment Number 4 1990 Fans On 205 deg F Fans Off 200 deg F Ron Davis Radiator 90 deg F Ambient at least 50% Coolant Mix Notes: 1. When testing Coolant Temperatures at Idle, then increasing the rpm, the Coolant Temperatures rose. This indicates the higher Coolant Temperatures at Idle are probably not caused by low pump flow. 2. The Water Pump Flow at 800 rpm is 15 gpm. The Water Pump actually gets more efficient as the rpm increases from idle to 2,000 rpm. As Per Marc Haibeck graph provided to the ZR-1 Net email list by Graham Behan about ten years ago, the water pump flow rate is: 15 gpm at 800 rpm 18 gpm at 1,000 rpm, 44 gpm at 2,000 rpm, 65 gpm at 3,000 rpm, 90 gpm at 4.000 rpm, 120 gpm at 5,000 rpm at which time cavitation is starting. 3. Marc pointed out "the high flow rate design of the water pump assured high volume of coolant through the cylinder heads to wash away boiling bubbles that lead to hot spots around the exhaust valves". Another reason blocking TB Coolant works so well as any remaining air in the coolant system gets washed back to the top of the Radiator and out the pressure relief . 4. The Dual Thermostat Bypass pressure is apparently 5 psi and block resistance at 100 gpm is approximately 20 psi. I am not sure what the radiator Head Loss is at various flow rates but definitely depends on the radiator type. 5. It would seem that the Coolant Pressure Relief Cap on top of the Coolant Expansion Tank in front of passenger side set at 15 psi would assure the radiator maximum pressure would be 15 psi plus the Bypass Pressure of 5 psi or 20 psi.
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 07-27-2014 at 12:06 AM. |
07-25-2014 | #42 | |
Re: Fluidyne radiator question
SInce you have a built 4 core rad, I would love to see the results of some water mist spraying on your rad, esp with your dry climate. It would work great. You are correct, the extra coolant capacity, thus the extra heat carrying capacity of your rad buys you time before you reach criticality. Kinda like wearing thick gloves vs. thin gloves. Once you grab a cherry hot piece of metal, you will get burned with either pair eventually, but the thicker gloves buy you time to shake them off. Once the air enters your rad, it can only take on so much heat. If the 1st core saturates the air with heat, the last 3 cores do nothing in regards to shedding heat. However if you can force more air through quickly enough, you will see some some advantage. The more air molecules you force through the rad, the more heat can be removed from the rad. Of course there are many variables at play. The packaging of the C4 is challenging. Anyone played with heat extractors to help get the underhood heat out?
peace Paul ZR-1 Net Registry Member #1494 |
07-25-2014 | #43 | |
I have no clue how one would direct heat coming through the Oil Cooler, AC Condenser, and Radiator downward under the engine and somehow directing cool air above the engine except a new hood design with louvers. The questions to be asked (specifically for those in the South West)...... 1. How long can you sit at a stop light with AC On (AC Fans medium to high) when the outside air temperature is 100 deg F or higher? 2. Secondly, how high do you let your Coolant Temperature get under those conditions? If you can sit indefinitely in 100 deg F Ambient Temperatures with the ZR-1 idling....what the hay do you have for radiator and fans? Any one driving a ZR-1 around Phoenix, AZ the next ten days?
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 07-26-2014 at 12:51 AM. |
07-29-2014 | #44 |
The problem I see with raising rpm is I think of the heat generated by the cyinders being absorbed into the coolant through the heads and block.. when you raise the rpm say from 1000 rpm to 1500 rpm.. that's 50% more compression cycles and more heat generated. I think the only way to truly compare pump flow.. would be to overdrive it or swap for an ewp .
My thoughts on heat extraction would be to do it like the c7. Angle the rad forward, make a plate directing flow through the rad straight upwards and have a cutout in the hood. Last edited by 5ABI VT; 07-29-2014 at 11:35 PM. |
07-30-2014 | #45 | ||||
If you can sit indefinitely in 100 deg F Ambient Temperatures with the ZR-1 idling....what the hay do you have for radiator and fans? Any one driving a ZR-1 around Phoenix, AZ the next ten days? [/QUOTE]
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 07-30-2014 at 08:49 AM. |
07-30-2014 | #46 | |
Your situation regarding NOT overheating at idle in 100 deg F must be attributed to the Header Coating and your Higher Flow Rate Spal Fans I would say. Thanks for the Information......
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 07-30-2014 at 10:38 AM. |
07-31-2014 | #47 |
Thank you for that tidbit. I've been reading this and wondering at what point do I start looking for a place to park.
07-31-2014 | #48 | |
"heat extractors" was brought up. A radiator is a heat extractor, but I also found that my high rise hood helped reduce temps. Not only more room above the engine, but vents in front of the windshield. Last edited by tf95ZR1; 07-31-2014 at 11:35 PM. Reason: Wanted 2 |
08-01-2014 | #49 | |
I'm sure this would be more pronounced at speed. Did you notice lower coolant temps or underhood temps? Were your vents akin to a cowl induction hood? My thoughs are that at a stop of slow speed, a "cowl induction" style of vent would work well, but at speed the high pressure area at the base of the windshield would lose its effectiveness. It seems that most guys have issues while idling around, so a hood like yours sound good. While at speed, you dont even need fans as the natural airflow across the rad is more effective.
08-01-2014 | #50 | |
My 98 STS had a similar very high 2nd fan enable temp, it was difficult to get that fan to engage from temps alone. Thats the nervous point, do I drive faster and try to cool the engine?, or do I pull over in some shade? Pulling over and shutting down will not cool like I want it to.
