10-21-2009 | #31 | |
Re: WAZOO (?) Parts Inventory?
I just got back from Westminster and I am hurting! Replaced all four rotors and vacuum flushed the system. I must be getting old.... |
10-22-2009 | #32 |
Available Parts List was updated.
Please go to the first post for the list. thanks. |
10-23-2009 | #33 |
Hey guys,
Since I'm kind of out in the wilderness here in the people's republic of NY I could add my spare parts to your list? Should I send some one an inventory sheet using e-mail or a PM? I've got quite a few items that obviously would be duplicates of what you all have listed in your inventory. I could filter my inventory list for the dupes or you could edit it as you guys see fit? Oh, sorry I don't know how to use any of those spread sheet programs.
10-23-2009 | #34 |
Tom,
You can e-mail to me and I will add to the list and have you on e-mail distribution list as well. b.i.yun@cox.net |
03-28-2010 | #35 |
I now have a lot of replacement bolts for the coolant pipes. These are black oxide finished steel bolts with 5mm allen heads. They look fairly close to stock, close enough anyway. They cam in a box of 50, and I only need 8.
I also have two OEM bolts that are in ok shape (the torx head anyway, the threads need to be cleaned up) and two that are in pretty poor shape.
03-29-2010 | #36 | |
02-02-2011 | #37 |
Just to send it to the top.
02-05-2011 | #38 |
Thanks Yun for being the Keeper of the List.
Since it got brought to the top, it reminded me to add some more items: AC Compressor, new, 2 U-Joint - drive shaft, new, 4 U-Joint - half shaft, new, 2 U-Joint strap Kit, new, 1 Differential, Dana 44, used 3.93:1 gear Oxygen Sensor, new, 1 Oxygen Sensor, used, 2 Clamp, Coolant Hoses (set), new, 1 Ignition Coil, new, 8 Tensioner, Drive Belt, new, 1 Bell Housing, used, 1 Fork, Clutch, used, 1 Stud, Clutch Fork, used, 1 Flywheel, Dual Mass, used, 1 Starter, used, 1 Throttle Body (includes:TPS,IAC), used, 1 Pump, Fuel, new, 2 Driveshaft (with front spline piece), used, 1 Jim |
02-05-2011 | #39 |
Re: WAZOO Parts Inventory
I have to apologize for not sending my parts list.....I haven't looked at my inventory for a few yrs. If I get my apartment cleaned up this week end I will make an honest attempt to go thru what I have an make an accurate list.
I'm searching my inventory for all my used PCV valves...yea I change them every yr and save the take outs. I know I'm out where the buses don't run! Now I'm glad I did that because our second valve went extinct at GM. The replacement I got from Rockauto isn't exactly what I would call a quality item. I'm going to try the local napa store to see if Standard make a replacement. Sorry guys.
