05-28-2015 | #31 |
Re: Jumper to avoid being stranded with a failed Primary Fuel Pump
Count me in for two sets.
Nelson007
WAZOO MEMBER 1993 #124 Ruby 1994 #??? Red/Black 1995 #061 Black/Red 2012 ZR1 Preproduction |
05-28-2015 | #32 | |
05-28-2015 | #33 |
For the length of the jumper, I recommend 8 to 12 inches. That length allows the harness to be pushed below the rubber boot one "lump" at a time. Then the wire can be pushed in. If the jumper is too short, the whole rigid part becomes bigger than the opening.
All that said, there is plenty of room below the rubber boot for the connectors and wiring. On a different subject, I recommend that if you use the jumper to swap a failed primary fuel pump, you should turn the Power Key OFF. Without the second fuel pump operating, if the secondaries opened, there might be a problem with a lean condition due to insufficient fuel supply. Jim |
05-28-2015 | #34 |
Add one here... Thanks
05-28-2015 | #35 | |
Jim |
05-28-2015 | #36 | |
Guy said he will do a long custom measurement with end to end wiring. It will be heat shrinked or wire wrapped to prevent chaffing. Once I have the proto type in hand I will post up the pics and the ordering instructions. Sound good? GC
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 06-03-2015 at 12:14 AM. |
05-28-2015 | #37 |
Sign me up for one.
Hope I never need it... |
05-28-2015 | #38 |
I'm in for 2 also
05-28-2015 | #39 |
If there is an option to buy surplus backshells and pins, I would be interested for that as I can (and would prefer) to make my own wiring to keep it cheap.
05-28-2015 | #40 |
Ok 17 and the parts have been ordered
