04-09-2013 | #31 | |
Re: Spindle fatigue?
The 63-82 factory differential side yokes were not hardened. The ends would wear and fatigue. The replacements "are" hardened.
04-09-2013 | #32 |
I swear he has never seen my shaft.
AL. I have the shafts made out of 4340 and heat treated through out,then I rework the spindles to fit the new bearings. The cost of the stub axles is $1150.00 bearings,studs and the lug nuts another $400.00 and $600.00 for labor. AL. |
04-09-2013 | #33 | |
You are too modest.
04-10-2013 | #34 | |
04-10-2013 | #35 |
04-10-2013 | #36 |
This is a very interesting thread. Al showed me his new spindle when I stopped at his shop a while back--very impressive. I solve the problem by having cheap tires that don't hook up too well. --Bob
04-10-2013 | #37 |
very interesting and informative....this is sort of the opposite of the road racing setup Z owners thread...power, yes, but much more attention on the suspension and especially the brake system working well at high stress loads. Two different key emphasis situations.
Lance Pearson Chester, Virginia [COLOR=red][I]'76 L48 four speed[/I][/COLOR] [COLOR=red][I]'91 ZR-1 #00682[/I][/COLOR] Net Registry #1461 |
04-10-2013 | #38 | |
That what I said! Al's shaft or spindle was impressive. BTW, the cheap tires that don't hook well, not such a good idea when you hit second gear.
04-10-2013 | #39 |
I didn't want to say it quite the way you did.... And on the tires, the Sumis hook up reasonably well for street tires, especially if I drop a few pounds of pressure. But as you point out, one should be careful. --Bob
04-10-2013 | #40 |
Experience has few reward's
