12-01-2013 | #321 |
Re: TOP END REFINISHING
Split BLMs are nothing new for the LT-5 especially at idle. Not a reason to buy new injectors. Were these the originals or replacements? One of the issues I discussed regarding the proper injector offset. As it is, these aren't bad. Can u tell if LEARN is ON?
12-01-2013 | #322 | |
Can't I assume that it IS on? Since the Short Term is closer to 128, than Long Term? Doesn't 'Learn' begin a few minutes after CL starts? No one chimed in to ID the injectors by the snappics, and I SURE don't know. Anyway here, why did the thing turn @ 3k when I ran it with IAC dis-connected earlier? Could it have been because of the vac leak @ the plenum-PCV connector? Re-try IAC dis-connect first thing AM...
12-01-2013 | #323 |
FWIW...after I replaced my injectors and O2's my Datamaster file CL showed both banks long term trims to be pretty steady at 128/129 L-R. Short term varied slightly about 127-130 for a 15min idle run.
I can tell you that originally I had a bad primary fuel injector (6 ohms hot) (12 ohms cold) on the left bank that gave the same rich indication that you have on your right bank Lterm. I don't know if that helps or muddies the water more. Without knowing the part number of your injectors its a hard guess if they are original or not but I will tell you my original injectors looked pretty much the same as yours in the pics. I think I mentioned this wayyyyy back in this thread. I would ohm the primaries out cold and hot and write them down. |
12-01-2013 | #324 | |||
[SIGPIC][/SIGPIC]Former Membership Chairman Former ZR-1 Registry - BOD 1972 Corvette 4speed base Coupe SOLD long time ago 1984 Corvette Z-51/4+3 SOLD 1992 Corvette ZR-1 Aqua/Gray #474 SOLD 1992 Corvette ZR-1 Black Rose/Cognac #458 2014 Honda VFR Interceptor DX Last edited by XfireZ51; 12-01-2013 at 09:22 PM. |
12-02-2013 | #325 | |
Will re-try IAC dis-connect again shortly here. This should be done Closed Loop? Or Open?
12-02-2013 | #326 | |
12-02-2013 | #327 | ||
Next? ed.: Quote:
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] Last edited by Schrade; 12-02-2013 at 02:37 PM. |
12-02-2013 | #328 |
Just trying to clarify, with IAC disconnected, warm idle was at 2200rpm? I am looking at 2 different scenarios you just posted. If O/L went smoothly, I would discount an issue w the injectors.
Remove the IAC completely and plug up that port physically making certain that no bypass air is entering. What's your idle at coolant operating temps and C/L? Is your motor completely stock or what mods have been done
12-02-2013 | #329 |
OK - I think I understand - 'block the port' for by-pass air.
Which of the 2 internal ports is this? The port in the SIDE of the IAC bore? Or in the END of the IAC bore
12-02-2013 | #330 |
The IAC pintle has HEAVY corrosion on it. I know this did not seal.
I hit it only with solvent, and THAT wouldn't touch what I have here...
