08-06-2009 | #21 | |
Re: Hello!
Oh, I have some videos of it here: http://www.youtube.com/user/aodnabisco#play/uploads And I believe the one video I have in there of the nice sounding ZR-1 is a member on this board somewhere. God that thing sounds gorgeous! |
08-06-2009 | #22 |
Re: Hello!
Well, I just ordered the Corsa exhaust for her.
08-06-2009 | #23 |
Re: Hello!
08-07-2009 | #24 |
Re: Hello!
Welcome to our obsession!
sorry for the circumstances of your loss. Tom Just a friendly reminder about lower T-stats, if you don't change the programed "on" & "off" temps on the chip a lower T-stat will work against you. Also, I'll bet there is a good deal of sand/dirt stuck in the fins even at 6909 miles. There was a good bit in mine after only 7400 miles. These cars run "hot" from the factory as it's part of the emissions management strategy. Also, if you are going to a thicker core, you may want to look into the second design fans as they move more air and that may help suck it thrui your Ron Davis core better than the early fan design. Corvette recycling has the whole assembly for about $100.00 + shipping. Sorry to be so nosey and foreward.
08-07-2009 | #25 | |
Re: Hello!
08-07-2009 | #26 |
Re: Hello!
As a side note, I fixed my passenger headlight last night. The inserts in the gear were completely dust. So, what I found that worked perfectly was a pack of window regulator gear plugs at the local auto parts store. The place is called Advanced Auto, but I'm sure your typical Vatozone and whatnot have it as well. It's in with all the other misc. interior junk like door lock knobs, window crank knobs, etc. These particular ones were from HELP! and they said they were for 2003-1965 Fords (yeah, the year range was backwards and everything). Anyhow, these work very well as this is exactly what they are for and there are even the right number of plugs for the gear in the pack. I assume the gear in the headlight motor is basically just a window regulator gear.
08-07-2009 | #27 |
Re: Hello!
Sorry, I should have included this link to Marc Haibeck's site....
http://www.zr1specialist.com/ Tons of stuff in the way of tech discussions over there and great reading! Did you do both head lights? I had one acting up and the brothers told me to do them both. Tom Our chips are ROM, read only memory. You have to pull the chip, write the changes, then load the changes to the chip....antique electronics...we can't "talk" to our chips while they're in the ECM like the OBDII suff.
1990 ZR-1, Black/grey, #2233, stock. ZR-1 Net Reg Founding Member #316 & NCM member Last edited by tomtom72; 08-07-2009 at 09:40 AM. Reason: I'm forgetfull |
08-07-2009 | #28 | |
Re: Hello!
So then the chip is a PROM? Either way, I'm guessing I'll either have to purchase a PROM writer or send the chip to someone. |
08-07-2009 | #29 |
Re: Hello!
Try this link for instructions on just doing the bushings. I used it and I had an easy time of it.
http://home.comcast.net/~zrjuan/headlight.html I didn't take apart the motors, just the gear cases. The only rub is the large gear. You will have to modify it a tiny bit...no really easy mod. Even I didn't muck it up! Yes, we are OBDI and our "chips" are a removable EPROM. We can't "talk" to it and write to it if it is mounted in the ECM. Check out the link in my other post for one source to get either yours re-written or I think Marc will sell outright also....don't quote me on the "sell outright" though... Tom
08-07-2009 | #30 | |
Re: Hello!
What modification did you have to do to your gear? Using the window regulator gear plugs I didn't have to make any modifications to the gear at all. If there is a way to get the main gear out without removing the worm gear I'd love to hear it. |
