05-22-2008 | #21 | |
Re: Jumped the gun still having stumbling issues
no o2 Ground is its own ground..
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - 3" Magnaflow Bullet cats - LT4 Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
05-23-2008 | #22 | |
Yes, a code did come up. I was at Doug Rippie's place when the code occured. Doug did not give me a code # but said it was the cam sensor fault.
05-23-2008 | #23 |
Jeff,
Have you thought of looking at the ECM grounds? Odd that O2 sensor ground would be bad. |
05-23-2008 | #24 | |
One step at a time.. going to check this fix this weekend. see if I got anywhere. then move on to the next issue
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - 3" Magnaflow Bullet cats - LT4 Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 Last edited by -=Jeff=-; 05-23-2008 at 10:13 AM. |
05-23-2008 | #25 | |
05-23-2008 | #26 | |
05-23-2008 | #27 | ||
Again, from what I read in the Service manual they seem to be fine.
05-23-2008 | #28 | |
05-25-2008 | #29 |
Update..
Injectors are FINE, Coils FINE.. I am working out a coupe things and don't want to speak too soon, but I thank I might almost have the issue resolved
05-25-2008 | #30 |
I'm on pins and needles!
