06-22-2020 | #21 | |
Re: ECM Issues - No Start
06-23-2020 | #22 |
Verifying that the primary injectors are working is actually straightforward:
Remove the Yellow or Gray 22-way Connector to the ECM. Turn the key to ON. One at a time, jump a wire from the (-) Battery Post to positions 1, 2, 3, 7, 8, 12, 13 and 18 on the Connector. An injector that makes an audible click, is likely OK. To check the primary and secondary injectors together, remove the Brown 22-way Connector to the ECM. Jump positions 16, 17, 21 and 22 from the connector to GND. Then remove the Yellow or Gray 22-way Connector to the ECM. Turn the key to ON. One at a time, jump a wire from the (-) Battery Post to positions 1, 2, 3, 7, 8, 12, 13 and 18 on the Connector. Both the primary and secondary injectors that make an audible click together, are likely OK. To check only the secondaries remove Injector 1 Fuse while doing the above tests. See page 6E3-A-5 of Factory Service Manual. Last edited by Macroblock; 06-24-2020 at 01:52 PM. |
06-23-2020 | #23 |
The ECM is out of the way of most of the engine heat so, the Arduino should be ok, sandwiched between the ECM's 2 PC boards.
I've used Arduinos on hundreds of devices, many in harsh environments, so I am confident it will be fine. As I test a few hundred iterations of the code I wrote, I will monitor the Arduino for signs of heat distress. |
06-23-2020 | #24 |
I do have great photos, but I wasn't able to upload them to this thread unfortunately. I suspect, I'll have to post them elsewhere and link them.
06-23-2020 | #25 | |
1990 Corvette ZR-1 #1051 Watson Headers (2" Primary) - 3" Magnaflow Bullet cats - LT4 Catback Late Model IH - Plenum Coilovers - 4.10s Custom Interior NCM Lifetime Member #978 |
06-25-2020 | #26 |
I have found that if the LT5 has a dirty, clogged or malfunctioning injector, this manual 'force' activation technique can sometimes help.
06-26-2020 | #27 |
Just discovered a serious error in the 1990 "RED" Edition of the Factory Service Manual that relates to the Camshaft Sensor.
Code 31 on page 6E3-A-50 describes the sensor as having a 0-5 volt output. This is incorrect. It is Ignition Voltage which is usually 11-14 volts. The correct voltage "(about 12 volts)" is referred to on page 6E3-C1-3. This matters if you're reworking the ECM like I am at the moment! |
06-26-2020 | #28 |
Macroblock, have been watching this thread with fascination, no clue about the technical side of this but impressed that you certainly understand and have fixed the one component that is rare, expensive and could shut us down if it goes south. Well done and thank you for posting!! I think this would make for a great article with photos for the Heart of the Beast and as Ccmano (Hans) suggested, a great side business if you have the time and enjoy what you do.
06-26-2020 | #29 | |
So to clarify, are Brown pins 16,17,21,22 all grounded simultaneously before moving onto Yellow/Gray connector? Or are they done individually w corresponding pins on Yellow/Gray?
06-26-2020 | #30 |
I think he is using a 1990 FSM
