Old 07-01-2017   #21
Default Re: Brakes Dragging on 1993 ZR-1
Originally Posted by Marc Haibeck View Post
Every time I have seen that problem it was caused by the master cylinder.
It's easy to determine for sure if the master is the problem. Have a brake line wrench in the car. Drive until the dragging is felt. Then loosen a brake line nut on the master cylinder. If the car rolls freely immediately after releasing the pressure, the master cylinder was the cause.
Marc's comments are always worth their weight in gold. He does not comment on problems too frequently, but when he does he is always worth listening to, as he had pretty much seen it all....Bob
Old 07-01-2017   #22
dnobull
Mark,
I have spoken with you on the phone regarding another issue with a vacuum leak. Certainly do appreciate your expert feed back. The releasing of pressure on the Master cylinder will be at the top of my list.
Thanks,
Dave Noble
dnobull is offline   Reply With Quote
Old 07-01-2017   #23
Flyman 27
Flyman 27's Avatar
Originally Posted by dnobull View Post
Thanks for your reply, I think I will replace the Calipers or have them re built and do the Brake lines at the same time,
Dave Noble 1993 #180
While you are replacing stuff, make sure that you purge out all the old brake fluid & replace it. You want to remove as much crud as you can.
Sounds to me like a sticking caliper, seen it before. But, it should have been obvious when the calipers were being retracted for the install of the new pads...
That part doesn't make sense.
Flyman 27 is offline   Reply With Quote
Old 07-01-2017   #24
dnobull
Thanks for your reply. Yes we will replace the fluid. Since I am having someelse do the work I will have to be sure that the master cylander is in the clear first. Marc Haibeck geve me a simple test to clear it. Then if that is not the issue it will be Calipers and Brake hoses.
You guys are terrific to reply with such details. I hope this the last thing to repair to have a perfect #180 This car has been through a lot, but the Buck stops here. If I ever sell it the next owner will get a perfect car.
Dave Noble
Tags
brake problems, brake solutions, brakes, dragging
