Old 02-17-2020   #21
WVZR-1
Default Re: ALDL Fault Codes
Perhaps the harness fabricator using this wiring diagram can explain how to accomplish what -=JEFF=- suggested. Or perhaps have the PROM 'modded'! A PROM mod might certainly be more practical.
'91+ Power Switch.jpg.
Old 02-17-2020   #22
Perry Mitchell
I am going to talk to Marc Haibeck about reprogramming my prom. He should be able to make any necessary changes to my early AXFK prom correct?
Perry Mitchell is offline   Reply With Quote
Old 02-17-2020   #23
I believe you will still need the resistor
Watson Headers (2" Primary) - 3" Magnaflow Bullet cats - LT4 Catback
Old 02-18-2020   #24
WVZR-1
A conversation is certainly less expensive and a 'non-destructive' start I'd think. The harness sounds as if it was a somewhat 'generic' fabrication. Much might depend on the ECM pinning that's actually populated in the harness. A 90 doesn't have C18 or C22 populated so if the fabricator uses a very basic approach I'd think Marc could get you squared away with a 'solution'. The solution might or might NOT be PROM mod.
Old 02-18-2020   #25
Perry Mitchell
So let's back up a minute. What does the 66 code mean? Is the system locked in valet mode or full power mode or somewhere else?
Old 02-18-2020   #26
WVZR-1
The rest of the diagnostic page !
That's why I suggested a 'conversation' with maybe the fabricator. Marc is also a good choice! If you don't have the 'switch' and the IGN power i'd think you have immediate issues.
Do you have the '91 ECM 'pin-outs' to confirm what you have for a harness to the ECM?
Old 02-19-2020   #27
Perry Mitchell
I talked to the harness manufacture, (Ron Francis Wire Works) and he is being helpful in resolving this code 66 issue. Can someone please tell me where I can find a schematic showing the ECM pin locations with their corresponding numbers on the ECM connectors? I tried searching this forum and Marc's website to no avail. Thanks for all your help.
Old 02-19-2020   #28
WVZR-1
PERRY
I sent you a PM. I do not recall your email from the work to correct your VSS issues. I have all that you could need for all years ECM. I believe maybe the best for you might be an entire FSM for the correct year that Ronn Francis Suggests. I can do that. I'm guessing the suggested might be a '91. I've got that and if they might have suggested a '90 I have that also. Either OR both aren't an issue!
I sent you the GREEN - C Connector Pin-Outs, also RED - B and I'll get a FSM ready for you!
-Dave
Old 02-20-2020   #29
Perry Mitchell
Thank you Dave. I will be talking to you soon.
Old 02-20-2020   #30
Corvette95
Corvette95's Avatar
Jumping in late, so this a LT5 transplant? I see the post about 12 to 16 pin adapter... if you left an obd2 plug on an earlier -pre-95 (95 has the obd2 even though it is a hybrid)it could be an issue, as far as the power key, another member made a good point of the power key you are using 91 or 90. Also, do you know if the secondaries or other may have been removed? While I don't think this applies , Vetronix makes an OBD2 interface for the Tech1A that works perfect. Happy to help but WVZR-1 is the man. But I am here if I can help.
1994 C4 Coupe Wht/Blk SOLD
1990 C4 ZR-1 Red/Red #0454
