06-10-2014 | #21 |
Re: saying hello
Make sure you drain just a bit of coolant to get the coolant level below the top of the Injector Housings. I also Plug TB coolant at the top of the Injector Housings making it easy to pull the plenum without messing with coolant the next time you pull the plenum. You also have to block the coolant flow from the TB to the top metal tank in front of the passenger side (I placed a plug in the rubber hose).
Good Luck Waiting for SD Plates ULNOTWN
Left Clickable links -Solutions- LT5 Modifications/Rebuild Tricks Low Mileage ZR-1 Restoration 1990 Corvette (L98) Modifications LT5 Eliminated Systems LT5 Added Systems LT5/ZR-1 Fluids 1995 LT5 SPECIFIC TOP END REBUILD TRICKS Last edited by Dynomite; 06-10-2014 at 11:03 PM. |
06-11-2014 | #22 |
Re: saying hello
Carter makes a nice plug for that rubber hose.
Was that a plug for Carter, or a plug from Carter? Huh. |
06-11-2014 | #23 |
Re: saying hello
back in the days when i had patience and my 91 L98( RIP) i did some tinkering around the map sensor....i remember adding a tee there for a test port..for probably ten years that puppy ran with a white golf tee plugging that test port..
06-13-2014 | #24 |
Re: saying hello
Welcome. Be sure to post after you get those secondaries fixed, because I think "pleasantly surprised" doesn't even come close to what you're going to feel. More like "HOLY SH*T! ..... Now,THAT'S what ZR-1's are all about.
I wouldn't start ripping out the secondary system before you actually get it functioning right. Because unless you're doing some serious porting and intake work, I'm not sure there is an actual performance advantage. Mine's been functioning fine with no maintenance for 23 years. Just sayin' Best of luck.
"It's about the car, not the people." 1991 ZR-1 White/Black #1236 (Owner since 1994). Stock engine with bolt-ons: Hurst shifter,"Forced Air" intake, Coplon duct, Bee Cool Radiator, Demon coils, Jeal prom, Watson headers, X pipe, 3" B&B's, Rippie flywheel, 4:10 gears, A molds, Toyo Proxes-R888's 12.06@117mph. 1.76 60ft. |
06-13-2014 | #25 |
Re: saying hello
i am considering the disabling of the system not for a performance advantage, just the reliability associated with it..i hear of no real down side from the system disablement ,other than perhps some low rpm torque loss ..which seems negligible..i dont race, minute numerical advantages dont matter to me.. push me back hard in the seat and im happy..so either way the plenum has to come off..
