09-17-2013 | #21 | |
Re: Fuel Pressure
I generally agree, although the response focused on the high results with the vac line off.....was not sure if he noted the PSI drop note As noted before, there are examples of this with other cars on the net doing the same; oddly no one posts their findings, just post the issue...many with new pumps or AM FPRs
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 09-17-2013 at 09:31 AM. |
09-17-2013 | #22 | |
Re: Fuel Pressure
09-17-2013 | #23 | |
Re: Fuel Pressure
Why wouldnt you use an IFR that is without the vaccuum source plugged in? The purpose of a vaccuum refernced FPR is to keep the pressure differential across the fuel injector as close to a constant as possible. As pressure increases inside the intake(vaccuum decrease) like when goiing to WOT, the VRFPR(vac reference fuel pressure regulator) will increase fuel pressure differential equal. Lower plenum pressure(high vaccuum-throttle closed) requires less rail pressure, and higher plenum pressure(low vaccuum-open throttle) requires less rail pressure. So if you input an IFR based off of actual injector flow that is reduced because of plenum vaccuum, your WOT fueling would be off. I am just used to entering IFR based off of unrefernced fuel rail pressure. Such as when getting rail pressure at KOEO(Key On Engine Off) which will be the same rail pressure with the engine running vaccuum refernced detached. It seems like using IFR based on unrefernced rail pressure, then let the VRFPR do its work when idling or cruising when plenum pressure is low(vaccuum is high). Using Marc's pressures 43 psi should be observed at idle vaccuum source attached, or 51 psi at KOEO or vaccuum source detached. Yes, no? Hmmmm??
peace Paul ZR-1 Net Registry Member #1494 Last edited by Hog; 09-17-2013 at 11:52 AM. |
09-17-2013 | #24 |
Re: Fuel Pressure
Marc's numbers
Yes, faulty fuel pressure regulator. On an LT5 the fuel pressure should be 3 Bar or 43 psi at idle with the manifold vacuum on the regulator. With the vacuum hose off or at WOT the fuel pressure should be 51 PSI +/- 1 psi. In the range of 45 to 55 psi each psi of pressure changes the AFR about .1. At 60 PSI at WOT you could be running an AFR point rich. VS. LGAFF's numbers Idle with FPR connected 50lbs Idle with FPR disconnected....60lbs Free Rev with FPR connected drops to 40lbs Free Rev with FPR disconencted 60lbs xxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxxx xxxxxxxxxxxxxxxxxxx I find it concerning that a free rev causes you FP to drop down to 40psi, thats without load as well.
peace Paul ZR-1 Net Registry Member #1494 |
09-17-2013 | #25 | |
Re: Fuel Pressure
I do as well, I just wanted to make sure there is no anomaly that could cause it, just as a car cannot build boost without load, maybe there is a reason for this....I am retesting the car today to see if there is anything shutting off the 2ndry pump
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 09-17-2013 at 12:59 PM. |
09-17-2013 | #26 | |
Re: Fuel Pressure
It doesn't work like this for carbs or TBI systems where a VAFPR causes the injectors to flow more by increasing FP. Accels, for example, are rated 21# at 39psi FP. Since our nominal FP is 43psi, the injector flow rate is ~23#. All of this is critical in calculating what the Base Pulsewidth is. Based on the BPC, the ECM increases or decreases pulsewidth to meter fuel as needed. An inaccurate BPC affects the rest of the fueling.
[SIGPIC][/SIGPIC]Former Membership Chairman Former ZR-1 Registry - BOD 1972 Corvette 4speed base Coupe SOLD long time ago 1984 Corvette Z-51/4+3 SOLD 1992 Corvette ZR-1 Aqua/Gray #474 SOLD 1992 Corvette ZR-1 Black Rose/Cognac #458 2014 Honda VFR Interceptor DX Last edited by XfireZ51; 09-17-2013 at 01:15 PM. |
09-17-2013 | #27 |
Re: Fuel Pressure
Ok, here is what I have found;
*Key on, not running both pumps produce good pressure; *Using the Tech 1, I can turn on the 2ndry pump....it primes and the car idles, however the tech 1 is showing only .2 volts....plug in the primary pump....13.4 Rev the engine in the test mode, fuel pressure drops, dies So if all of this holds true a static test of pumps is basically worthless and only good to find an absolute failure...
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 09-17-2013 at 06:06 PM. |
09-17-2013 | #28 | ||
Re: Fuel Pressure
You ARE saying FPR VACUUM dis-connected, just to be absolutely clear... right?
And if FPR isn't responding properly to vacuum [presence, or absence], could it be a vac leak? What was pressure leakdown time? Or is it holding static pressure? (sorry if you posted that and I missed it...) ''''''''''''''''''''''''''''''''''''''''' Is this FSM material? Quote:
I'm getting my snappics / threads removed blindly as fast as I can, to get in compliance with copyright / license TOS on the boards here (lots of FSM pages and other copyright / license violations on my part; sorry guys). And thanks to all the guys who didn't whine when I posted those FSM copyrighted / licensed stuff in my threads... ( :thumbsup: [b]and to think I complied with a mod's request to delete a pic of him in a Challenge Car in NCM Museum, so he wouldn't get in hot water)[/b] Thanks to several guys here for sending parts FREE; BearlyFlying, WeGone, Geezer, GoldCylon, and more there, TonyD, mike100, fletchusmc... 1990 #2794; 4L60e Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless, Power Effects 3" [IMG]https://lh5.googleusercontent.com/-GHpfzty7DVU/UQn-0Ru2xAI/AAAAAAAAA14/08mz1p4QLD4/s445/Screenshot-5.png[/IMG] Last edited by XfireZ51; 09-17-2013 at 11:22 PM. |
09-17-2013 | #29 |
Re: Fuel Pressure
No thats something I was testing, going to replace the secondary pump tomorrow....my only concern is that maybe the .2 is a reference and not the 2ndry pump voltage....
09-18-2013 | #30 |
Re: Fuel Pressure
In the words of Frankenstein:
FUEL PUMP BAD! Now it goes to 55+ when at WOT. Old Pump read 1.9 ohms, new 63 ohms, old Callaway pump I had laying around 58.....those who know more about electronics might have a thought on this...
LGAFF 90 #966-150K miles-sold 92 #234-sold 1987 Callaway TT #17 1991 ZR-1 #1359 Last edited by LGAFF; 09-18-2013 at 08:36 PM. |
