05-24-2012 | #21 |
Re: C4 Chassis Stiffeners from Killebrew
I have a brand new GM X-brace that I need to install sometime soon
05-25-2012 | #22 |
And I just know you'll take pictures and post'm right? =D>
05-25-2012 | #23 |
What I would like to know is where did you come up with a new GM cross brace? Costly?
05-25-2012 | #24 |
05-25-2012 | #25 | |
(the Killibrew setup would not be class legal for me - at least without an argument, and I would not likely win an argument at a national event) Best, - Jeff
[I]91 ZR-1 #1840, autocrossing in SCCA BSP. FIC S/S's DRM chip/Watson/Borla/lid/LW batt&headlights, springs, shocks, pads & lines, quick rack & Turn One, camber brace, 32/22mm sways, A/C halfway deleted 17x11 & 12 CCW's, 315 & 335 Hoosier A6s [/I] |
05-26-2012 | #26 |
To those of you with the stock brace, it looks like it would be prone to rattling with a 3" exhaust. Is it?
The stock brace does look subject to crimping. Would it be worthwhile to box it, or build one from rectangular tubing? Maybe boxing it would not be effective, if the brace is designed to cross tie the frame rails together rather than provide torsional rigidity. |
05-26-2012 | #27 | |
05-26-2012 | #28 |
I know that there's someone on the other forum that boxed the x brace, But I don't know that they had before/after opinions about it.
There is some contact between the brace and the y-pipe , you can see the area of rubbing in one picture above. I would like to avoid it but I haven't really noticed any vibration while driving, so it is low on my priority list. btw, hit 198k miles today!
05-27-2012 | #29 |
Whooo hoooo. This needs a "poll".
Who has the highest and lowest mileage?
05-28-2012 | #30 | |
Have the bottom stitch welded before install. Back in 93 I had it installed stock and was not completely stisfied. Took it to Corvette Masters in Maitland, Fl, had Robbie weld plates and close it off - a world of difference. |
