Old 03-27-2010   #21
Polo-1
Default Re: Camshafts almost done
my, what big lobes you have
Old 03-30-2010   #22
tpepmeie
First design was:
Intake 254@.050 .500" lift
exhaust 240@.050 .465" lift
Still tweaking the final specs... chasing an additional .020" intake lift , and trying to find the right valve springs.
Todd
Old 03-30-2010   #23
Pete
Pete's Avatar
Originally Posted by tpepmeie View Post
First design was:
Todd
Todd, the extra lift really worth the hassle?
Does it pick up that much more CFM and finding a spring.
Pete
'91 #1635 PoloGreen 350 LT5
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 03-30-2010   #24
tpepmeie
Pete
Pete, we'll see. My heads don't let up until past .550 lift, so I'd like to capture as much of that flow as we can. They gain another 20+ cfm from .450 to .550. I only have 39.5mm intake valves, versus 40mm for the LPE cars, so the extra lift helps with the flow area. Target = 700 hp. (720? if I'm lucky). This is the "just because" motor... I'm trying stuff just because nobody else has...
Old 04-01-2010   #25
Pete
Pete's Avatar
Todd,all the work and effort you put into this motor i hope you see 750hp
20 CFM is plenty and worth it,at least for me it would be.
Pete
11.09 @ 129.27
11.04 @ 128.86
474RWHP 400RWTQ
Old 04-01-2010   #26
flyin ryan
flyin ryan's Avatar
Try to get .020" more lift anyways, past where they turn the corner, if you can.
Old 04-01-2010   #27
tpepmeie
Here's the headflow curve up to .550 lift. about 10 cfm from .450 to .500, another +10 to .550, then it flattens out, only 2 cfm gain to .600. I have to double check the retainer to valve guide clearance to see if we can go above .500.
Old 04-05-2010   #28
First design was:
Todd
Todd,
Have you finalized an LSA you'll be installing cams at?
Old 04-05-2010   #29
tpepmeie
I think I've decided to stop at .500" lift. Spent the better part of the afternoon clearancing one head for the big lobes. Not sure I want to do it all again, and I can see where even more interference lurks if I go to 520. If I had a nice grinder like some of you guys it would go loads faster... but I was stuck using a dremel . Wore out three bits to get through all that aluminum, and I only did one head.
Old 04-06-2010   #30
How will that affect your final cam profile if not looking for that last 10cfm?
