09-18-2009 | #11 |
Re: Motor died while running, now no-start
Spoke to Jeffvette he said you would have to start pulling the electrical pins and swap them around to make the primary the secondary or run some patch cables around but would be probably easier to just swap the pump. He said there is also a procedure to jump wires next to the ecm to have both pump run at the same time. Not sure where that is although. He beleives the pump is the culprit as well. GC
09-18-2009 | #12 | |
Thanks for the info, Jeff. I swapped the pumps already, and got better fuel pressure than I ever had before (when I first installed the pump/sender assembly new out of the box, I got around 40-41psi. I figured that was low, but the car seemed to run fine... This time, with the pumps swapped, it ran up to just under 50psi, I heard the regulator bleed off a little pressure, and it settled in around 45psi. Guess I need to fire off an email to the partsladi now. Thanks Daryl and Jeff! |
09-18-2009 | #13 | |
09-18-2009 | #14 | |
Apparently, if you buy something from partsladi, save your boxes and receipts. These are both needed for warranty returns. Last edited by VetteMed; 09-18-2009 at 07:14 PM. |
09-18-2009 | #15 | |
I can ship you my empty fuel pump box. Well it will be empty when I remove the pumpladi fuel pump out of it that is. Just send me your empty when it (replacement pump) returns. It came from the Ladi. Do you have the receipt?
09-18-2009 | #16 |
They claim there's a barcode on the part that has to match each individual pump -- I'm calling BS on that, I don't see a barcode anywhere on the pump or sender assembly. I'm tempted to just buy the Suburban pumps elsewhere and be done with them. This assembly was made in China anyway, which made me a little leery when I installed it.
09-18-2009 | #17 | |
GOLDCYLON - 91 ZR-1 #2014 GOLDCYLON - 90 ZR-1 #2794, 4L60e (Formerly Schrade's) GOLDCYLON - 11 CTS-V Arizona State Director 91 WHITE/BLACK #2014. 380 P&P&PCed,Ported Heads, Jeal Long tubes, Corsa Exhaust/FIKSE FM-5s /LED TLs, LED Headlights, Front Wilwood 6 piston narrowlite calipers and rear Wilwood caliper street shop mod,CNCed Coolant Pipes,TPI Cvr,Filter cover,Stainless Bolts, DRM/DOM PROM /ZFDOC mod build #102,DRLs,BMAD with stainless Debris Screen,Coplan Air Blaster, Pioneer APP Radio 4,Brey-Krause HB,Sub Bar,Fire extinguisher seat mount,DRM Coilovers,LEDs everywhere,Compass mirror (orange),V1 DIC hidden display, Homelink sun visor, Carbon Fiber top x3 and APSIS Carbon Fiber interior, APSIS CF Steering Wheel/NAPA Leather, Banski trailing arms, Guldstrand front suspension,urethane bushings from Prothane (total suspension) ZFDoc drive shaft safety loop, raptor shift light (orange),AO engineering louver front plate, Console seat cushion, 96CE seats with black custom Sheepskins, ss billet catch can,Viper remote entry/alarm,Cragar Rear Louvers,LED side louver lights, Dewitts Radiator with SPAL fans and a Woods 160 T-Stat 90 RED/BLACK #2794. 4L60e Automatic Stage V by RPM Transmission, TCI Dedicated TCM, OBX Stainless Headers, Corsa Exhaust, SAN Secondaries and Haibeck PROM, Exotic Muscle Coil overs, LED Interior Lights, LED Tail Lights, LED Headlights, 94 Sport seats with black custom Sheepskins , Cragar rear louvers, GS Front calipers, Banski Trailing arms, APSIS Carbon Fiber steering wheel, Front and Rear Baer Eradispeeds, DRLs, Guldstrand front suspension,urethane bushings from Prothane (total suspension), Dewitt's Raditor with Dual SPAL fans and a Haibeck 170 T-Stat 11 RED/GREY CTS-V Last edited by GOLDCYLON; 09-18-2009 at 04:56 PM. |
09-18-2009 | #18 | |
09-18-2009 | #19 |
Did you buy it on Ebay and use Paypal?
09-18-2009 | #20 |
Well crap my pump was in a Corvette Central box. If you can hook Andrew up please pm him thanks GC
