View Poll Results: Which oil do you use?
Amsoil 79 22.13%
Castrol 19 5.32%
Champion 0 0%
Chevron 0 0%
Conoco 0 0%
Citgo 0 0%
Havoline 1 0.28%
Interstate 0 0%
Kendall 1 0.28%
Lowe 0 0%
Marathon 0 0%
Mobil 1 224 62.75%
Motorcraft 0 0%
National 0 0%
PennZoil 4 1.12%
Quaker State 3 0.84%
Redline 10 2.80%
Royal Purple 11 3.08%
Valvoline 5 1.40%
Voters: 357. You may not vote on this poll
Old 03-27-2007   #11
birddog01
Smile Re: Which oil do you use
Just switched to M1 Extended.
birddog01 is offline   Reply With Quote
Old 03-28-2007   #12
Z Factor
Z Factor's Avatar
Lightbulb Re: Which oil do you use
I am a Mobil 1 user as well. Aside from having a great product I try to support them as much as possible because they have supported the ZR-1 in various ways such as Morrison's record run.
Old 03-29-2007   #13
Aurora40
Aurora40's Avatar
Default Re: Which oil do you use
Originally Posted by 40th#381
I use M-1 Reg If you want Zink use M-1 Extended
Jan
I believe M1 Extended has the same lack of zinc now. That is what I've been using to date though.
Bob Saveland
Former owner of #2517
Old 03-30-2007   #14
M1 oil & filters. In everything I own. M1 is just my choice due to GM recommendation & easy to find, not to mention I've never had any oil related problems with M1.
Old 03-30-2007   #15
GrayZ
Cool Re: Which oil do you use
Mobil 1...is the choice in my vehicles...
wesson in the frying pan.
GrayZ is offline   Reply With Quote
Old 03-31-2007   #16
I use 10-30 M1 full syn because everyone else does! Plus I can buy it in six qt boxes at the local Costco....they're closer & cheaper than any of the local auto parts stores.
Old 04-05-2007   #17
Sgreg
Sgreg's Avatar
Amsoil, still has the zinc and is cheaper than Redline. Tests even better than Mobil 1 and Redline.
1991 ZR-1, Black, Black, # 541
Sgreg is offline   Reply With Quote
Old 04-05-2007   #18
Z Factor
Z Factor's Avatar
Question Re: Which oil do you use
I am sure everyone would be very interested in seeing any tests that were conducted if you have a source?
Old 04-05-2007   #19
guinnessdood
guinnessdood's Avatar
Using Mobil 1 Extended Performance...it contains 50% more of their Super Syn...super syn is the stuff that makes their oil super slippery. Lately I have noticed that the price of the Extended Performance has really jumped compared to the regular Mobil 1. I guess they decided they weres ellin it too cheap...
Uly
Past OWNER 90 ZR-1 #0120 Red/Saddle
UT Plate: EZR1DER
guinnessdood is offline   Reply With Quote
Old 04-05-2007   #20
Aurora40
Aurora40's Avatar
According to Amsoil, they do not have high levels of ZDDP. It seems they don't feel it is necessary, they claim to have other anti-wear additives instead:
http://www.amsoil.com/dealer/techser...shaft_lube.pdf
Bob Saveland
