Old 05-23-2012   #11
VetteMed
Default Re: C4 Chassis Stiffeners from Killebrew
Pics of x-brace installed on '91 Z, with Jeal headers. Hard to get good pics, since I don't have a lift, but let me know if something different is needed.
Rear shot of RH rear mounting location, to show relationship to trailing arm mount area
Exhaust clearance pics in next post.
Old 05-23-2012   #12
VetteMed
Old 05-23-2012   #13
scottfab
scottfab's Avatar
What a great set of pics!
What is that just above the tennis shoes on the X brace?
It looks like a crimp in the X brace right near that bolt head.
Scott
Old 05-23-2012   #14
Where they welded the fastener for the bolts to go through?
Old 05-23-2012   #15
Here are some not so awesome shots of the Killebrew Brace
https://picasaweb.google.com/1013380...8/C4FrameBrace
can you see it in this pic?
Old 05-23-2012   #16
VetteMed
Scott, not sure where you're referring to exactly. Right above the shoes is the RF mounting location, and I don't see a bolt there in that pic?
Old 05-24-2012   #17
scottfab
scottfab's Avatar
look above the tennis shoes until you see the exhaust pipe.
Now find the rusty part on the exhaust pipe.
Now just left of the top part of the rust spot....see the bolt head?
Now right there just above the bolt head see the crumpled section on the X member? Did that happen installing or under load?
Scott
Old 05-24-2012   #18
scottfab
scottfab's Avatar
[QUOTE=-=Jeff=-;141844]Here are some not so awesome shots of the Killebrew Brace
/QUOTE]
Those are great too. Show more of where the mounts go than the other link to the Killebrew hardware.
Scott
Old 05-24-2012   #19
VetteMed
Scott, that "bolt head" is the drain plug for the ZF6.
The section of x-brace in that area has an area contoured to accommodate the exhaust piping, and that wrinkled area looks to me to be done intentionally in the process of stamping of the part.
Old 05-24-2012   #20
scottfab
scottfab's Avatar
You're right.
I downloaded and zoomed in and can see the cooling fins on the ZF6 now and the threads on the side of the plug. After zooming the "wrinkled" area looks to be a crumbled area from stress. Anyone else see that? There is a curve cut on the other side of the piece but several inches away.
I'm sure it all functions very well as is. I just wonder if this area takes all the movement over and over.
This is the first X brace I've seen. Again, thanks for posting.
Scott
